TP LINK SafeStream TL-ER7206 Gigabit Multi-WAN VPN Router
Quicklinx: G6WRWS00 Mfr#: TL-ER7206
Hassle-Free Centralized Cloud Management:
100% centralized cloud management of whole network from different sites—all controlled from a single interface anywhere, anytime.
Internet Access Management Strategy
Standardize users’ online behavior and easily specify the internet access rights and strategies of employee via IP/MAC/URL Filtering and Access Control List (ACL). Captive Portal authentication facilitates network resource control by capturing, authenticating, and classifying user access. Appropriate network resources can also be allocated for particular users or guests.
TP-Link SafeStream TL-ER7206 - V1 - router - desktop
Router
Enclosure Type
Desktop
Performance
VPN unencrypted throughput (PPTP): 1.3793 Gbps , VPN encrypted throughput (PPTP): 115.6 Mbps , VPN unencrypted throughput (L2TP): 1.3603 Gbps , VPN encrypted throughput (L2TP): 202.3 Mbps , VPN throughput (128-bit AES IPSec): 291.6 Mbps , Routing throughput (1518-byte packet size): 81274 pps , Upload forwarding rate (66-byte packet size): 486918pps , Download forwarding rate (66-byte packet size): 488372 pps , NAT upload throughput (PPTP): 918.9 Mbps , NAT download throughput (PPTP): 914.7 Mbps , NAT upload throughput (L2TP): 918 Mbps , NAT download throughput (L2TP): 917.9 Mbps , NAT upload throughput (PPPoE): 939.7 Mbps , NAT download throughput (PPPoE): 937.9 Mbps , NAT upload throughput (DHCP): 940.3 Mbps , NAT download throughput (DHCP): 940.4 Mbps
New sessions per second: 5500 , Concurrent connections: 150000
Network / Transport Protocol
TCP/IP, PPTP, L2TP, NTP, IPSec, PPPoE, DHCP, DNS, HTTP, HTTPs
Routing Protocol
IGMPv2, static IP routing, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, ICMP
VoIP Protocols
H.323, SIP
NAT support, Syslog support, URL filtering, DPD, IPSec NAT-T, virtual server support, DHCP server, reset button, bandwidth control, port triggering, IP-MAC binding, GARP, Captive Portal, ARP inspection, 4KV Surge protection, network diagnostics, Web Filtering, policy based routing, PFS, ZTP, L2TP support, DynDNS, schedule reboot, OpenVPN server, Block TCP Flood, Black UDP Flood
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, UPnP
22.6 cm x 13.1 cm x 3.5 cm
UNIX, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10
Router
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, MD5, MPPE, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, IKEv1, 3DES-168
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, UPnP, FCC, RoHS, EIA/TIA-568
RAM
512 MB DDR3 SDRAM
Flash Memory
128 MB
Status Indicators
Power, system, link/activity, speed
IP Telephony
VoIP Protocols
H.323, SIP
WAN / LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x Ethernet 1000 - SFP (mini-GBIC)
Internal power supply
Installed Qty
1
22.6 cm
13.1 cm
3.5 cm
10 - 90% (non-condensing)
