TP LINK RE650 AC2600 WiFi Range Extender
Quicklinx: F9JSWS00 Mfr#: RE650
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 2600Mbps
Protocol: IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11a + 1 more
Compatibility: PC, Mac
  • IEEE 802.11n
£77.47 ex VAT
£92.96 inc VAT
Powerful quad-antenna design with Beamforming delivers highly targeted Wi-Fi connections to improve throughput and signal quality for stronger Wi-Fi across your home, while extending your routers coverage. The Intelligent Processing Engine balances the demands of your devices to keep their connections fast and uninterrupted, sending Wi-Fi traffic to dedicated processors while the powerful CPU handles the rest. Using 4-Stream and TurboQAM technology to boost its Wi-Fi bandwidth, the RE650 reaches industry leading maximum speeds. This provides the performance necessary to support your demanding online applications. MU-MIMO technology allows the RE650 to serve up several devices at once, reducing wait time and greatly increasing Wi-Fi throughput for every device. With MU-MIMO, the RE650 runs faster than traditional AC range extender. The RE650's Gigabit Ethernet port lets you connect a wired device such as a game console or smart TV to create a fast, reliable wired connection. If one of the main router's dual bands drops suddenly, or in case the main router can only deliver single band, the RE650 still provides stable dual-band connections for clients, allowing you to enjoy stable and drop-free experience on all your devices.
  • Far reaching Wi-Fi and powerful performance
  • 4-Stream dual band Wi-Fi
  • More connections and faster for everyone
  • High-speed Gigabit wired connection
  • Drop-free and seamless dual band connections
TP-Link RE650 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
1 x 880 MHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
8.6 cm x 4 cm x 16.3 cm
8.6 cm
4 cm
16.3 cm
United Kingdom
Processor / Memory / Storage
Processors Installed
1 x 880 MHz
External
Wireless
Data Transfer Rate
2600 Mbps
Frequency Band
2.4 GHz, 5 GHz
Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, beamforming technology, 4x4 MU-MIMO technology, Intelligent Signal Light
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External integrated
Antenna Qty
4
1 x 1000Base-T - RJ-45
FCC, RoHS
Internal power supply
12 Watt
10 - 90% (non-condensing)
Speed: 2600Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Compatibility: Mac
Antennas: 4
Brand: TP LINK
