- RE605X comes equipped with the latest wireless technology, Wi-Fi 6, for faster speeds, greater capacity, and reduced network congestion.
 - Creates a Mesh network by connecting to a TP-Link OneMesh™ router for seamless whole-home coverage.
 - Gigabit Ethernet Port – Provide faster-wired connections to smart TVs, computers and gaming consoles
 - Intelligent Signal Light – Helps to determine the best location for optimal Wi-Fi coverage by indicating the signal strength in the current placement
 - AP Mode – create a new Wi-Fi access point to enhance your wired network with Wi-Fi capability
 - TP-LINK Tether App – Easily access and manage your network using any iOS or Android mobile device
 - Ultimate Compatibility – Extend the range of any Wi-Fi router or wireless access point
Get more range with your existing router
RE605X wirelessly connects to your existing router and boosts more Wi-Fi signals throughout your home, allowing you to enjoy smooth Wi-Fi 6 network experiences everywhere with great speed, capacity, and coverage. -
More connections with better performance
Wi-Fi 6 technology is built for today's devices, eliminating lag, endless loading, and dead spots. It fully satisfies your network needs especially for bandwidth-intensive tasks like cloud gaming or 4K video. -
Adaptive path selection
Keeps your network running at top speed by automatically choosing the faster connection path to the router. -
Built-in access point mode
RE605X is more than a wireless range extender. Simply plug an Ethernet cable into its Ethernet port, and easily turn your wired internet connection into a 2x2 MU-MIMO dual-band wireless access point.
 - TP-Link RE605X - Wi-Fi range extender - Wi-Fi 6
- Form Factor
 - In-wall mountable
- Data Link Protocol
 - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
- Frequency Band
 - 2.4 GHz, 5 GHz
 - 74 mm x 46 mm x 124.8 mm
 - 220 g
 - 2-year warranty
 - 74 mm
 - 46 mm
 - 124.8 mm
 - 220 g
- Form Factor
 - In-wall mountable
- Connectivity Technology
 - Wireless, wired
- Line Coding Format
 - 1024 QAM, OFDMA
- Frequency Band
 - 2.4 GHz, 5 GHz
 - Wi-Fi Protected Setup (WPS), MU-MIMO technology, OneMesh support
- Encryption Algorithm
 - WPS
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
- Antenna
 - External integrated
- Antenna Qty
 - 2
 - 1 x 1000Base-T - RJ-45
- Power Device
 - Internal power supply
 - Limited warranty - 2 years
