RE505X comes equipped with the latest wireless technology, Wi-Fi 6, for faster speeds, greater capacity, and reduced network congestion. Creates a Mesh network by connecting to a OneMesh router for seamless whole-home coverage.
The 505X wirelessly connects to your router, boosting your Wi-Fi 6 signal throughout your home so you can binge watch your favorite show anywhere. RE505X is more than just a wireless range extender. Simply plug an Ethernet cable into its port to easily turn that wired connection into a high-speed dual band wireless signal.
Gigabit Ethernet port
Provide faster-wired connections to smart TVs, computers and gaming consoles. -
Intelligent signal light
Helps to determine the best location for optimal Wi-Fi coverage by indicating the signal strength in the current placement. -
AP Mode
AP Mode - create a new Wi-Fi access point to enhance your wired network with Wi-Fi capability. -
TP-LINK Tether App
Easily access and manage your network using any iOS or Android mobile device. -
Ultimate compatibility
Extend the range of any Wi-Fi router or wireless access point.
- TP-Link RE505X - Wi-Fi range extender - Wi-Fi 6
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Maximum data rate (5 GHz): 1200 Mbps , Maximum data rate (2.4 GHz): 300 Mbps
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 10
- 7.4 cm x 4.6 cm x 12.48 cm
- 280 g
- 2-year warranty
- 7.4 cm
- 4.6 cm
- 12.48 cm
- 280 g
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 1500 Mbps
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Wi-Fi Rating
- AX1500
- Status Indicators
- Power, 5 GHz, 2.4 GHz, Wi-Fi
- Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, Intelligent Signal Light, WPS button, 4K UHD video streaming, Wi-Fi 6 technology, OneMesh support, Adaptive Path Selection
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.3ax
Aerial
- Antenna
- External
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- FCC, RoHS
- Power Device
- Internal power supply
- 10 Watt
- OS Required
- Limited warranty - 2 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FT7W 051214 Condition: Damaged stock - Item is new but has packaging damage |
£23.40 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
