TP LINK RE505X AX1500 Wi-Fi 6 Range Extender
Quicklinx: FT7WWS00 Mfr#: RE505X
Type: Wi-Fi range extender
Speed: 1500Mbps
Connectivity: Wired, Wireless
Pass-through Socket: No
  • IEEE 802.11n
£39.26 ex VAT
£47.11 inc VAT
RE505X comes equipped with the latest wireless technology, Wi-Fi 6, for faster speeds, greater capacity, and reduced network congestion. Creates a Mesh network by connecting to a OneMesh router for seamless whole-home coverage.
The 505X wirelessly connects to your router, boosting your Wi-Fi 6 signal throughout your home so you can binge watch your favorite show anywhere. RE505X is more than just a wireless range extender. Simply plug an Ethernet cable into its port to easily turn that wired connection into a high-speed dual band wireless signal.
  • Gigabit Ethernet port
    Provide faster-wired connections to smart TVs, computers and gaming consoles.
  • Intelligent signal light
    Helps to determine the best location for optimal Wi-Fi coverage by indicating the signal strength in the current placement.
  • AP Mode
    AP Mode - create a new Wi-Fi access point to enhance your wired network with Wi-Fi capability.
  • TP-LINK Tether App
    Easily access and manage your network using any iOS or Android mobile device.
  • Ultimate compatibility
    Extend the range of any Wi-Fi router or wireless access point.
TP-Link RE505X - Wi-Fi range extender - Wi-Fi 6
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (5 GHz): 1200 Mbps , Maximum data rate (2.4 GHz): 300 Mbps
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 10
7.4 cm x 4.6 cm x 12.48 cm
280 g
7.4 cm
4.6 cm
12.48 cm
280 g
External
Wireless, wired
Data Transfer Rate
1500 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX1500
Status Indicators
Power, 5 GHz, 2.4 GHz, Wi-Fi
Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, Intelligent Signal Light, WPS button, 4K UHD video streaming, Wi-Fi 6 technology, OneMesh support, Adaptive Path Selection
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.3ax
Aerial
Antenna
External
Antenna Qty
2
1 x 1000Base-T - RJ-45
FCC, RoHS
Internal power supply
10 Watt
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FT7W 051214
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £12.11
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Speed: 1500Mbps
Connectivity: Wired
Connectivity: Wireless
Brand: TP LINK
Stock Status: Used Stock
