The AC1200 Wi-Fi Range Extender connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own, achieving speeds of 300Mbps on the 2.4GHz band and 867Mbps on the 5GHz band.
Intuitive Web UI
Ensures quick and simple installation without hassle. -
Fast encryption
One-touch wireless security encryption with the WPS button -
LED On/Off
Conveniently turn on or off LEDs as required. -
Power On/Off
Conveniently power on or off your extender as required. -
Hassle-free management with Tether App
Network management is made easy with the TP-Link Tether App, available on any Android or iOS device. -
Ultimate wireless speed
Wireless speeds of up to 300Mbps on the 2.4GHz band and 867Mbps on the 5GHz band. -
Support 802.11 AC
Provides a data transfer rate 3 times faster than 802.11n for each stream. -
Fast Ethernet port
Acts as a wireless adapter to connect wired devices. -
Simultaneous dual band
Separate Wi-Fi bands enable more devices to connect to your network without a drop in performance. -
Reliable connection
Two adjustable antennas for optimal Wi-Fi coverage and reliable wireless connections. -
Universal compatibility
Works with any Wi-Fi router.
- TP-Link RE365 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- France
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
- 7 cm x 7.7 cm x 12.5 cm
- 3-year warranty
- 7 cm
- 7.7 cm
- 12.5 cm
- Localisation
- France
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 1.2 Gbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Wi-Fi Rating
- AC1200
- Status Indicators
- Power
- Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- FCC, RoHS
- Power Device
- Internal power supply
- 8 Watt
- OS Required
- Limited warranty - 3 years
