The TP-Link AC1200 Wi-Fi Range Extender connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own. The device also reduces signal interference to ensure reliable Wi-Fi coverage throughout your home or office.
Blazing fast Wi-Fi speed
Provides faster dual band Wi-Fi access with Wi-Fi standard - 802.11ac technology. -
Gigabit Ethernet port
Act as a wireless adapter to connect wired devices at gigabit speed. -
Reliable connection
Dual adjustable external antennas for optimal Wi-Fi coverage and reliable wireless connections. -
Simultaneous dual band
Reduces interference for more stable connections. -
Smart signal indicator
Smart signal lights help to find the best location for optimal Wi-Fi coverage by showing the signal strength. -
One button easy setup
Press the WPS button on both your router and your RE350 to easily get the Wi-Fi expanded in minutes. -
Universal compatible
Works with any Wi-Fi router or wireless access point.
- TP-Link RE350 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- 7.5 cm x 4.3 cm x 12.6 cm
- 7.5 cm
- 4.3 cm
- 12.6 cm
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 1200 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Access Point operational mode, reset button, wireless extender mode
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- FCC, RoHS
- Power Device
- Internal power supply
- 11 Watt
- OS Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
