The RE305 lets you keep more devices connected at the same time with its 2.4GHz 300Mbps and 5GHz 867Mbps dual bands. Use the 2.4GHz band to send email and browse the web, and the 5GHz band for gaming and HD streaming. An Intelligent Signal light helps you quickly find the best location to install the RE305.
High-Speed dual band Wi-Fi for better connections
The RE305 lets you keep more devices connected at the same time with its 2.4GHz 300Mbps and 5GHz 867Mbps dual bands. Use the 2.4GHz band to send email and browse the web, and the 5GHz band for gaming and HD streaming. -
Perfect location at a glimpse
An Intelligent Signal light helps you quickly find the best location to install the RE305. -
Built-in access point mode
RE305 is more than a wireless range extender. Simply plug the Ethernet cable into its Ethernet port to easily turn your wired internet connection into a dual band wireless access point. -
Easy management and remote control
The RE305 works with all Wi-Fi routers. You can use TP-Link free Tether app to set up the range extender from any Android or iOS device in minutes. This feature-rich phone app allows you to enjoy not only hassle-free installation, but also access to advanced network management, all at your fingertips.
- TP-Link AC1200 Wi-Fi Range Extender RE305 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
- 8 cm x 7.8 cm x 7.7 cm
- 8 cm
- 7.8 cm
- 7.7 cm
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1200 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- DHCP support, MAC address filtering, Access Point operational mode, wall mountable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), reset button
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- FCC, RoHS
- Power Device
- Internal power supply
- 7.3 Watt
- OS Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
