TP LINK RE220 AC750 Wi-Fi Range Extender
Quicklinx: FT81WS00 Mfr#: RE220
Type: Wi-Fi range extender
Speed: 750Mbps
Connectivity: Wireless
Pass-through Socket: No
  • IEEE 802.11n
£22.19 ex VAT
£26.62 inc VAT
Boost Your Wi-Fi to hard-to-reach Areas
Place the RE220 between your wireless router and wireless devices, expanding Wi-Fi coverage while eliminating Wi-Fi dead zones. The dual-band Wi-Fi up to 750 Mbps can not only extend to 32,00 sq. ft. (300m2) with the router, but also make good use of your high ISP speed , ideal for HD video streaming, online gaming and other bandwidth-intensive tasks.
Stable Dual Band Connection for More Devices
The RE220’s Wireless AC technology creates faster and stronger Wi-Fi connections across your home and extends dual band Wi-Fi up to 750 Mbps. Dual 2.4 GHz and 5 GHz bands provide Wi-Fi connections to up to 32 devices, allowing you to enjoy stable and drop-free experience on all your devices.
  • An access point and wireless adapter
    The Ethernet port of RE220 can easily turn your wired Internet connection into a wireless access point. It can also function as a wireless adapter to connect wired devices.
  • High-speed mode for maximized performance
    High-speed mode uses one dedicated Wi-Fi band as backhaul and another dedicated Wi-Fi band as an access point to maximize the bandwidth on extender's Wi-Fi.
  • Universal compatibility
    The RE220 is compatible with any of your existing Wi-Fi router or access points, making it easy to expand and strengthen your Wi-Fi network.
TP-Link RE220 - Wi-Fi range extender - Wi-Fi 5
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 433 Mbps
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 10
7.52 cm x 6.58 cm x 11 cm
7.52 cm
6.58 cm
11 cm
External
Wireless
Data Transfer Rate
750 Mbps
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AC750
Status Indicators
Power, 5 GHz, 2.4 GHz, Wi-Fi
Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
3
1 x 100Base-TX - RJ-45
FCC, RoHS
Internal power supply
6.5 Watt
10 - 90% (non-condensing)
Speed: 750Mbps
Brand: TP LINK
