TP LINK Portable 3G/4G Wireless N Router
Quicklinx: DGCJWS00 Mfr#: TL-MR3020 V3
Type: Wireless router
Connection Type: WAN/LAN
Standards: Fast Ethernet, IEEE 802.11g, IEEE 802.11n, IEEE 802.11b + 1 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£19.66 ex VAT
£23.59 inc VAT
Express delivery Order within the next 5 hours for delivery tomorrow
What make this router outstanding are its travel-size design and Mini USB Port, which can be connected to a laptop or power adapter to be used as a power supply. As long as you have your laptop, the TL-MR3020 can be powered and a wireless cloud is created that can be shared by iPads, iTouches, Android Phones, Kindles and the vast majority of other portable Wi-Fi enabled devices.
Compatibility is the most important aspect to consider when you're selecting a 3G router. TP-LINK has made certain that 3G routers are compatible with the ISPs in the regions in which they are sold.
With one button security setup, the TL-MR3020 allows users to instantly setup their security simply by pressing the WPS button on the router and automatically establishing a WPA2 secure connection, which is more secure when compared with WEP encryptions. Not only is this faster and safer than normal security setups but more convenient in that users needn't remember a password!
Bandwidth of mobile broadband is limited. With the router's IP QoS function, the TL-MR3020 allows optimum utilization of bandwidth and offers bandwidth control over congestion, preventing bandwidth abuse. When sharing your mobile broadband with others, you can decide how the bandwidth is shared based on your requirements.
The TL-MR3020 can be installed quickly and easily almost anywhere. All you need to do is insert the USB modem into the router, search for its wireless SSID on your computer and connect to it. Users can be online and surfing the Internet in no time, with the user guide on provided CD, even novice users can easily set up their wireless Internet connections.
  • High compatibility-tested in field
  • One button security setup
  • IP QoS - control your bandwidth
  • Easy to use
TP-Link TL-MR3020 - v3 - wireless router - Wi-Fi - desktop
Wireless router
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
DoS attack prevention, IPv6 support, parental control, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), reset button, bandwidth control, IPv4 support, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, IP-MAC binding, DMZ support
UPnP
7.4 cm x 6.7 cm x 2.2 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
UPnP, RoHS
WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB: 1 x mini-USB Type B
Aerial
Aerial
Internal
External power adapter
1 x USB cable , 1 x network cable
7.4 cm
6.7 cm
2.2 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Standards: Ethernet
Speed: 300Mbps
Brand: TP LINK
