TP LINK PB5200 5200mAh Power Bank 5V USB Smart Charging LED
Quicklinx: BRPXWS00 Mfr#: TL-PB5200
Housed in an ergonomically designed case, TL-PB5200 is a high capacity 5200mAh power bank compatible with most of your digital devices. With full capacity, the TL-PB5200 holds enough juice to fully charge your device once or even more times.
  • Power your digital life on the move
  • Smart Charging
    Smart Charging Technology identifies your digital devices, and delivers the fastest possible charge for when you need it the most.
  • Fastest charging and recharging ever
    Supporting an input/output current up to 5V/2.4A, TL-PB5200 boasts the fastest charging and recharging speed for its category. TL-PB5200 is capable of charging phones and tablets at the fastest/ maximum speed that they are designed to be charged at, helping you get the most out of all your devices in the fastest time possible. The TL-PB5200 promises lighting fast recharging with the ability to recharge itself from empty to 90% in less than 2 hours with a 5V/2.4A power adapter.
  • Reliable power
    TL-PB5200 is a reliable power bank with superior quality that comes equipped with 6 in 1 complete safety protection against damage caused by short circuit, over-voltage, over-current, over-charge, over-discharge, and over-heating.
  • High energy efficiency rate
    Powered by TP-LINK's world class circuitry and advanced energy technologies, TL-PB5200 significantly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate.
  • Compatibility
    Compatible with iPhone, iPad, Android smartphones and most 5V input digital devices.
TP-Link TL-PB5200 power bank - USB
Power bank
5.35 cm x 2.2 cm x 9.27 cm
135 g
Output Connector Type
USB - on cable: Micro-USB
Max Electric Current
2.4 A
5200 mAh
Cables
Micro-USB cable
Power bank
5.35 cm
2.2 cm
9.27 cm
135 g
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2.4 A
LED indicator
Voltage Provided
5 V
5200 mAh
Overcharge protection, overheat protection, short circuit protection, overdischarge protection, overcurrent protection, overvoltage protection
Micro-USB cable
BRPX C2G 2m USB 2.0 A/B Cable - Black In Stock £3.63
