OC300, the hardware controller for the Omada Software Defined Networking (SDN) platform, provides 100% centralized management of access points, switches, and gateways - all controlled from a single interface.
Reliable performance
Powered by a Cortex-A72 processor with a clock speed of 1.2 GHz, ensuring efficient processing and rapid response times for network tasks. -
Extensive storage
Includes 8 GB of flash memory that enables effective storage and management of applications and configurations. -
High capacity management
Supports a maximum of 50,000 clients and up to 15,000 accounts, ideal for large environments needing robust network management. -
Enhanced security features
Equipped with multiple security features like VPN support, MAC address authentication, and DoS attack prevention, safeguarding network integrity. -
Versatile connectivity
Offers various data link protocols including Fast Ethernet and Gigabit Ethernet for flexible network connectivity options.
- TP-Link Omada OC300 - network management device - cloud-managed
- Network management device
- Form Factor
- Rack-mountable
- Processor
- 1 x Cortex-A72 1.2 GHz
- RAM
- 2 GB
- Flash Memory
- 8 GB
- Data Link Protocol
- Capacity
- Maximum number of clients: up to 15000 , Manageable access points: up to 500 , Maximum number of accounts: 1000 , Maximum number of vouchers: 50000 , Maximum number of WLAN groups: 500
- Included Accessories
- Rack mount kit
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
- Power
- AC 100/240 V (50/60 Hz)
- 29.4 cm x 18 cm x 4.4 cm
- 29.4 cm
- 18 cm
- 4.4 cm
Processor / Memory / Storage
- Processors Installed
- RAM
- 2 GB DDR4 SDRAM
- Flash Memory
- 8 GB
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- PPTP, L2TP, IPSec, DDNS
- Remote Management Protocol
- SNMP, SSH, RADIUS
- Cloud-Managed
- Capacity
- Status Indicators
- Power, cloud
- Routing, NAT support, VPN support, DoS attack prevention, URL filtering, firmware upgradable, Access Control List (ACL) support, reset button, Captive Portal, metal housing, event notification, MAC address authentication, schedule reboot, layer 3 management, security slot (Kensington security lock compatible)
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.1x
- 2 x 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A
- Rack mount kit
- Cables Included
- 1 x network cable
- FCC, RoHS
- Power Device
- Internal power supply
- Voltage Required
- 14.8 Watt
- OS Required
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
