TP LINK Omada EAP225-Wall AC1200 Dual Band Wall-Plate Access Point
Quicklinx: FT88WS00 Mfr#: EAP225-Wall
  • IEEE 802.11n
More than just a wireless access point, EAP225-Wall acts as a switch and provides three standard Ethernet jacks together with a Power over Ethernet outlet, capable of powering wired devices such as IP phones, IP cameras, intercoms and more. The EAP225-Wall blends seamlessly into any business setting with a refined, minimalist appearance. A slimline design includes casing that's just 11 mm in thickness. EAP225-Wall delivers combined dual-band speeds of up to 1200Mbps. Armed with the latest 802.11ac Wave 2 MU-MIMO technology, it can exchange data with multiple clients at the same time to allow more devices to connect without any slowdown to the network.
  • Complete in room Wi-Fi coverage
    An EAP in each room guarantees a strong wireless signal and allows guests to enjoy their own private Wi-Fi network.
  • Effortless deployment and scalability
    With 802.3af/802.3at Power over Ethernet supported there's no need to install additional wiring in the building. Simply plug in existing Ethernet cables and you're ready to go.
  • Installation made easy
    Upgrade Ethernet wall jacks to high-performance Wi-Fi access points. The EAPs can be fitted to existing EU or US wall junction boxes, making installation quick and non-disruptive.
  • Three Ethernet jacks, one PoE outlet
  • Perfectly formed
  • Gigabit Wi-Fi speeds with MU-MIMO technology
TP-Link Omada EAP225-Wall - radio access point - Wi-Fi 5
Radio access point
Wall mountable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs (2.4 Ghz): 8 , Maximum number of configured SSIDs (5 Ghz): 8
Wall mounting kit
Power Over Ethernet (PoE) Supported
PoE+
8.6 cm x 1.97 cm x 14.3 cm
Radio access point
8.6 cm
1.97 cm
14.3 cm
Wall mountable
Wireless
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC1200
Load balancing, VLAN support, Syslog support, manageable, E-mail alert, MAC address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, rogue access point detection, Captive Portal, MU-MIMO technology, scheduler, SSID to VLAN mapping, Wireless Scheduler, port-based VLAN
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA2, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
4
3 x 100Base-TX (PoE+) - RJ-45
Wall mounting kit
FCC, RoHS
PoE+
9 Watt
Software Included
Omada Controller
10 - 90% (non-condensing)
