The EAP115-Wall would blend seamlessly into any business setting with a refined, minimalist appearance. A slimline design includes casing thats just 11 mm in thickness.
Reliable connectivity
With a data transfer rate of 300 Mbps, the TP-Link Omada EAP115-Wall ensures a stable and efficient wireless connection for various devices, enhancing performance in home and office environments. -
Versatile installation options
The wall-mountable form factor allows for flexible installation, making it suitable for different locations while maintaining an organized setup. -
Enhanced security measures
Equipped with multiple encryption algorithms such as WPA2-Enterprise and WPA2-PSK, this access point ensures secure connections to keep your network protected from unauthorized access. -
Power over Ethernet functionality
The PoE capability simplifies deployment by allowing power and data to be transmitted over the same Ethernet cable, reducing the need for additional wiring and maintaining a neat appearance. -
Advanced networking features
Features like load balancing, multiple SSID support, and Quality of Service (QoS) enable better resource management and improved user experience across the network.
- TP-Link Omada EAP115-Wall - radio access point - Wi-Fi
- Radio access point
- Form Factor
- Wall mountable
- Localisation
- Europe
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Included Accessories
- Mounting screws
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista / 7 / 8 / 10
- Power Over Ethernet (PoE) Supported
- PoE
- 8.68 cm x 8.68 cm x 3.02 cm
- 8.68 cm
- 8.68 cm
- 3.02 cm
- Localisation
- Europe
- Form Factor
- Wall mountable
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS
- Load balancing, Syslog support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, Watch Dog Timer (WDT), SSID to VLAN mapping
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
- IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 1.8 dBi
- 1 x 100Base-TX (PoE) - RJ-45
- Mounting screws
- RoHS
- PoE
- 2.8 watt
- OS Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
TP LINK Omada EAP115-Wall 300Mbps Wireless N Wall-Plate Access Point
