TP LINK Omada EAP115-Wall 300Mbps Wireless N Wall-Plate Access Point
Quicklinx: FT8BWS00 Mfr#: EAP115-Wall
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11a, Ethernet, Fast Ethernet, IEEE 802.11g + 2 more
Compatibility: [N/A]
  • IEEE 802.11n
18 In Stock
£30.77 ex VAT
£36.92 inc VAT
The EAP115-Wall would blend seamlessly into any business setting with a refined, minimalist appearance. A slimline design includes casing thats just 11 mm in thickness.
  • Reliable connectivity
    With a data transfer rate of 300 Mbps, the TP-Link Omada EAP115-Wall ensures a stable and efficient wireless connection for various devices, enhancing performance in home and office environments.
  • Versatile installation options
    The wall-mountable form factor allows for flexible installation, making it suitable for different locations while maintaining an organized setup.
  • Enhanced security measures
    Equipped with multiple encryption algorithms such as WPA2-Enterprise and WPA2-PSK, this access point ensures secure connections to keep your network protected from unauthorized access.
  • Power over Ethernet functionality
    The PoE capability simplifies deployment by allowing power and data to be transmitted over the same Ethernet cable, reducing the need for additional wiring and maintaining a neat appearance.
  • Advanced networking features
    Features like load balancing, multiple SSID support, and Quality of Service (QoS) enable better resource management and improved user experience across the network.
TP-Link Omada EAP115-Wall - radio access point - Wi-Fi
Radio access point
Wall mountable
Europe
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Mounting screws
Microsoft Windows XP, Microsoft Windows Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE
8.68 cm x 8.68 cm x 3.02 cm
Radio access point
8.68 cm
8.68 cm
3.02 cm
Europe
Wall mountable
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS
Load balancing, Syslog support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, Watch Dog Timer (WDT), SSID to VLAN mapping
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
Gain Level
1.8 dBi
1 x 100Base-TX (PoE) - RJ-45
Mounting screws
RoHS
PoE
2.8 Watt
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Antennas: 2
Brand: TP LINK
