TP LINK Omada AC1200 Wireless MU-MIMO Gigabit Wall Plate Access Point
Quicklinx: G6WQWS00 Mfr#: EAP230-Wall
Type: Wireless router
Connection Type: WAN/LAN
Standards: Fast Ethernet, IEEE 802.11a, Gigabit Ethernet, IEEE 802.11g + 4 more
Speed: 300Mbps
Rackmount or External: Rack-mountable
  • IEEE 802.11n
£57.82 ex VAT
£69.38 inc VAT
EAP230-Wall is designed to meet every network need in environments with numerous separated rooms, like hotels, offices, and dormitories. A device in each room ensures an exclusive, high-speed Wi-Fi connection for every user.
  • MU-MIMO + dual-band: faster connection for more devices
    802.11ac wave 2 technology allows multiple users to access the internet at the same time. Speeds up to 1200 Mbps and 2.4 GHz and 5 GHz wireless bands deliver simultaneous high-speed internet access to various devices.
  • Seamlessly blends with any décor
    The same size and shape as a light switch or power outlet faceplate to fit in perfectly in any room.
  • High-speed Gigabit port
    Equipped with a Gigabit port to deliver the fastest possible wired transmission.
  • Effortless deployment with Power over Ethernet
    802.3af/802.3at PoE support means there's no need for extra wiring. Plug in existing Ethernet cables to transmit both power and data to your APs.
TP-Link Omada EAP230 - V1 - wireless router - Wi-Fi 5 - wall-mountable
Wireless router
Enclosure Type
Wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
HTTP, HTTPs
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS, SSH
Syslog support, E-mail alert, MAC address filtering, WMM support, ACL support, QoS, reset button, rogue access point detection, 802.1x authentication, cloud managed, MU-MIMO technology, beamforming technology, band steering, rate limit, Wireless Scheduler, LED on/off button, guest access, ZTP, schedule reboot
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2
8.68 cm x 3.02 cm x 8.68 cm
Microsoft Windows XP / Vista / 7 / 8 / 10
Wireless router
Enclosure Type
Wall-mountable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
HTTP, HTTPs
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
Secure Shell (SSH), Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2, RoHS
LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE+) - RJ-45
7 Watt
Mounting Kit
Included
8.68 cm
3.02 cm
8.68 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11a
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11ac Wave 2
Speed: 300Mbps
Brand: TP LINK
