EAP230-Wall is designed to meet every network need in environments with numerous separated rooms, like hotels, offices, and dormitories. A device in each room ensures an exclusive, high-speed Wi-Fi connection for every user.
MU-MIMO + dual-band: faster connection for more devices
802.11ac wave 2 technology allows multiple users to access the internet at the same time. Speeds up to 1200 Mbps and 2.4 GHz and 5 GHz wireless bands deliver simultaneous high-speed internet access to various devices. -
Seamlessly blends with any décor
The same size and shape as a light switch or power outlet faceplate to fit in perfectly in any room. -
High-speed Gigabit port
Equipped with a Gigabit port to deliver the fastest possible wired transmission. -
Effortless deployment with Power over Ethernet
802.3af/802.3at PoE support means there's no need for extra wiring. Plug in existing Ethernet cables to transmit both power and data to your APs.
- TP-Link Omada EAP230 - V1 - wireless router - Wi-Fi 5 - wall-mountable
- Wireless router
- Enclosure Type
- Wall-mountable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz / 5 GHz
- HTTP, HTTPs
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, HTTPS, SSH
- Syslog support, E-mail alert, MAC address filtering, WMM support, ACL support, QoS, reset button, rogue access point detection, 802.1x authentication, cloud managed, MU-MIMO technology, beamforming technology, band steering, rate limit, Wireless Scheduler, LED on/off button, guest access, ZTP, schedule reboot
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2
- 8.68 cm x 3.02 cm x 8.68 cm
- System Requirements
- Microsoft Windows XP / Vista / 7 / 8 / 10
- Wireless router
- Enclosure Type
- Wall-mountable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- HTTP, HTTPs
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA2-Enterprise
- Authentication Method
- Secure Shell (SSH), Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2, RoHS
- LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE+) - RJ-45
- 7 Watt
- Mounting Kit
- Included
- OS Required
- 8.68 cm
- 3.02 cm
- 8.68 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
