TP LINK Omada AC1200 MU-MIMO Wall Plate Access Point
Quicklinx: G6WPWS00 Mfr#: EAP235-Wall
Type: Radio access point
Connectivity: Wireless
Speed: [N/A]
Protocol: IEEE 802.11ac Wave 2, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
12 In Stock
£35.83 ex VAT
£42.99 inc VAT
Standard delivery Delivered within 3-5 working days
An EAP in each room allows guests to enjoy their own private Wi-Fi network that's fast, delivering a strong signal, and providing corner to corner coverage.
  • Connect faster and more
    802.11ac wave 2 MU-MIMO technology enables multiple users to access the Internet simultaneously, which largely boosts up your network speed of up to 1,200 Mbps. Capable of transmitting in both 2.4 GHz and 5 GHz wireless band, it provides greater compatibility to connect varieties of devices.
  • Effortless deployment with PoE-powered
    With 802.3af/802.3at Power over Ethernet supported there's no need to install additional wiring in the building. Simply plug in existing Ethernet cables and you're ready to go.
  • Quick, simplified installation
    EAP235-Wall is easy to install, so extra cost, time, or professional knowledge are completely unnecessary.
  • Full Gigabit ports to bridge network
    Equipped with four Gigabit data ports, one downlink port offering PoE passthrough, to connect multiple devices to your Gigabit network. Wired devices like VoIP phones can be powered with no need for extra electrical cables.
TP-Link Omada EAP235-Wall - radio access point - Wi-Fi 5
Radio access point
Wall mountable
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs (2.4 Ghz): 8 , Maximum number of configured SSIDs (5 Ghz): 8
Wall mounting kit
Microsoft Windows XP / Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE+
8.6 cm x 2 cm x 14.3 cm
Radio access point
8.6 cm
2 cm
14.3 cm
Wall mountable
Wireless
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC1200
Load balancing, E-mail alert, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), reset button, rogue access point detection, MU-MIMO technology, beamforming technology, band steering, SSID to VLAN mapping, rate limit, VLAN management
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Secure Shell (SSH)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Antenna Qty
4
Gain Level
4 dBi
3 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T (uplink) - RJ-45
Wall mounting kit
FCC, RoHS
PoE+
9.8 watt
10 - 90% (non-condensing)
Speed: [N/A]
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Antennas: 4
Brand: TP LINK
