TP LINK N600 Wireless Dual Band Gigabit ADSL2+ Modem Router
Quicklinx: 8NZ4WS00 Mfr#: TD-W8980
  • IEEE 802.11n
TP-LINK's N600 Wireless Dual Band Gigabit ADSL2+ Modem Router TD-W8980 is an incredibly robust all-in-one device combining the crystal clear 5GHz band and the traditional 2.4GHz band.
With 600Mbps of total bandwidth, simple tasks like sending e-mails can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
Its all gigabit ports allow users to access high-speed internet connections and share them wirelessly at blazing 300Mbps wireless speeds or by using one of its 4 gigabit LAN ports.
With 2 multifunctional USB ports, users can share printers (PC Only), files and media across the local network or the internet. What's more, this All-in-one device allows for two different connection types: ADSL, or Ethernet WAN, giving users the flexibility to access the Internet whichever method is most convenient.
Clear up your desktop!
The TD-W8980 does the work of several networking devices packed into one sleek device. With an ADSL2+ Modem, NAT Router, 4-Port Switch and Wireless N Access Point, this device eliminates the need to purchase multiple devices to access and share a high-speed internet connections.
Simultaneous Dual Band
Two separate wireless networks that will run on either the 2.4GHz or 5GHz band, simultaneously. The traditional 2.4GHz band can provides more range and is great for everyday web surfing use but it is more susceptible to interference from wireless devices running on the same frequency. While the 5GHz band can provide faster wireless speeds and avoid much interference .This way, the 5GHz band is just right for bandwidth heavy tasks like on-line gaming and HD streaming. Now you can enjoy both advantages of the two bands by just having one device.
Full Gigabit Ports - More Power to You
With 300Mbps 802.11n wireless and 4 gigabit LAN ports, the TD-W8980 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
2 USB Sharing Ports - Easy Sharing
Using the TD-W8980's two multi-functional USB 2.0 ports, users can share printers (PC Only), files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files.
Interchangeable LAN/WAN Port - Versatile Connectivity
The TD-W8980 supports ADSL or Ethernet WAN connections (EWAN) that allow users to have the flexibility of different Internet connections among ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
IPv6 Ready
This device supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
Virtually Impregnable-10 VPN IPsec tunnels
The ability to support up to 10 IPsec VPN tunnels simultaneously gives TD-W8980 users the flexibility to setup a virtual private network, to guarantee network security and take advantage of network access whether at home or away, for work or simply to access files from their local networks.
  • Clear up your desktop
    The TD-W8980 does the work of several networking devices packed into one sleek device. With an ADSL2+ Modem, NAT Router, 4-Port Switch and Wireless N Access Point, this device eliminates the need to purchase multiple devices to access and share a high-speed Internet connection.
  • Simultaneous dual band
    Two separate wireless networks that will run on either the 2.4 GHz or 5 GHz band, simultaneously. The traditional 2.4 GHz band can provides more range and is great for everyday web surfing use but it is more susceptible to interference from wireless devices running on the same frequency. While the 5 GHz band can provide faster wireless speeds and avoid much interference .This way, the 5 GHz band is just right for bandwidth heavy tasks like on-line gaming and HD streaming. Now you can enjoy both advantages of the two bands by just having one device.
  • Full Gigabit ports - more power to you
    With 300 Mbps 802.11n wireless and 4 gigabit LAN ports, the TD-W8980 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
  • 2 USB sharing ports - easy sharing
    Using the TD-W8980's two multi-functional USB 2.0 ports, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files.
  • Interchangeable LAN/WAN port - versatile connectivity
  • IPv6 ready
  • Virtually Impregnable-10 VPN IPsec tunnels
TP-Link TD-W8980 - wireless router - DSL modem - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
IPSec VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, FTP, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP
Firewall protection, DMZ port, DHCP support, NAT support, traffic shaping, Stateful Packet Inspection (SPI), print server, MAC address filtering, IPv6 support, URL filtering, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, file sharing, Quality of Service (QoS), Dead Peer Detection (DPD), virtual server support, Wi-Fi Protected Setup (WPS), Samba support, FTP server, port triggering, Stateful Packet Inspection Firewall (SPIF)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n, UPnP
24.3 cm x 16.06 cm x 3.25 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
DES, Triple DES, MD5, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n, UPnP, FCC, RoHS
Communications
DSL modem
ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.995.1
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Phone line: 1 x ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
ADSL splitter
1 x phone cable , 1 x network cable
24.3 cm
16.06 cm
3.25 cm
10 - 90% (non-condensing)
8NZ4 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
