Tp-Link Tapo Mini Smart Wi-Fi plug with Energy monitoring
Matter Certified Integrate Matter-certified Tapo devices with other Matter end products into your preferred ecosystem Energy Monitoring - Set your electricity rate to estimate your energy bills offers more comprehensive insights into home appliances' power consumption with more intuitive and straightforward data visualizations Note: Energy Monitoring feature is not supported by Matter yet but coming soon. Please use this feature in the Tapo app for now Compact Design - Mini-sized to avoid blocking adjacent outlets Voice Control Manage your smart plug with voice commands via Amazon Alexa Apple Siri or Google Assistant
- Tapo P110M V1 - smart plug - Bluetooth, 802.11b/g/n
- Product Type
- Smart plug
- Environment
- Indoor
- Functions
- Energy use monitor, remote control
- Power Source
- Power socket
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Connectivity
- Wireless - Bluetooth, 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- 2-year warranty
- 5.15 cm x 3.06 cm x 7.25 cm
- Product Type
- Smart plug
- Environment
- Indoor
- Functions
- Power Source
- Power socket
- Connectivity Technology
- Wireless - Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- Up to 3680 Watt, Away Mode, voice control, LED indicator, timer, overload protection, flame-retardant, automatic switch-off function, 16 A max load current, schedule function, rust proof, child safety shutter Bluetooth for onboarding only, Matter compatibility
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- Tapo app
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Voice Controlled
- Indirect
- Product Material
- Polycarbonate
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP, WPA3
- Voltage Required
- AC 100-240 V
- Rated Current
- 13 A
- Warranty
- 2-year warranty
- RoHS, UL 94 V-0, UKCA
- 5.15 cm
- 3.06 cm
- 7.25 cm
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
