TP LINK M9 Plus AC2200 3-Pack
Quicklinx: G2SXWS00 Mfr#: DECO M9 PLUS(3-PACK)
Type: Wi-Fi system
Connectivity: Wired, Wireless
Speed: 2134Mbps
Protocol: IEEE 802.11a, Ethernet, IEEE 802.11ac, IEEE 802.11n + 5 more
Compatibility: Android, Apple iOS
  • IEEE 802.11n
£291.66 ex VAT
£349.99 inc VAT
Deco is a simply way to guarantee a strong Wi-Fi signal in every corner of your home up to 4,500 square feet. Enjoy fast and secure Tri-Band Wi-Fi no matter how many devices you have. Deco M9 Plus connects and controls your smart home devices as a hub, no need for additional hub.
Seamless Coverage
Achieve seamless whole-home coverage with a mesh Wi-Fi system and eliminate weak signal areas once and for all.
One Unified Network
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
Broad Coverage
Enjoy Wi-Fi coverage up to 6,500 square feet with just 3 Deco M9 Plus units and expand it by just adding more Decos.
Fast Connections
Three separate wireless bands up to 2134 Mbps with a dynamic backhaul up to 1.5 Gbps ensure stable, high-speed connections wherever you are in your home.
Seamless Management
Deco M9 Plus acts as a hub for your wireless and smart home devices. See compatible list >
Connect Multiple Devices
Deco handles traffic from even the busiest networks, providing lag-free connection for over 100 devices.
Total Security
HomeCare provides personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS)* to ensure a safer online experience.
Setup Made Easier Than Ever
The Deco app walks you through setup -- step by step.
  • More than dedicated wireless connection
    Three separate Wi-Fi bands deliver super-fast, stable connections to devices in every room of your home. More bandwidth is freed up with dedicated wireless links between Deco units. Say goodbye to lag with AC2200 Wi-Fi system. Deco M9 Plus uses not only 5G 1(867Mbps) as wireless backhaul but also 5G 2(867Mbps) and 2.4G(400Mbps) as backhaul while traffic gets heavy, delivering speeds over 1000Mbps which is ideal for your gigabit fiber.
  • Dead-zone killer
    Eliminate weak signal areas with whole-home Wi-Fi. No more searching around for a stable connection. Want more coverage? Simply add another Deco.
  • No more buffering
    Tired of endless loading? With an ever increasing number of bandwidth-hungry gadgets in your home, you need a network that can rise to the challenge. With network speeds three times faster than the previous generation routers thanks to 802.11ac wireless technology, Deco can provide lag-free connections for over 100 devices.
  • Whole home seamless roaming
    Deco units work together to form one unified network. Enjoy your smart life without interruption not just in your living room, but all around your entire house with Deco M9 Plus's smart mesh.
  • The smart hub of your home
    Deco M9 Plus acts as a smart home hub, bringing all your products together in one easy-to-use app. Set interactions between Zigbee, Bluetooth and Wi-Fi devices. With Deco M9 Plus, enjoy the magic of the smart home in every room.
  • Great compatibility
    TP-Link smart devices, GE, Kwikset and other leading brands are supported, making possible a range of interactions between bulbs, locks, cameras and more.
  • Setup just got a lot easier
    Unbox Deco, install the app and then simply follow the on-screen directions. Deco will take care of the rest, getting your network up and running in minutes.
TP-Link Deco M9 Plus - Wi-Fi system - Wi-Fi 5, Bluetooth, ZigBee Home Automation 1.2 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
Wi-Fi System Coverage
Up to 6,750 sq.ft
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2134 Mbps
Network / Transport Protocol
PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
IPv6 support, parental control, Access Point operational mode, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, dynamic IP mode, DHCP client, anti-virus protection, router mode, TP-Link Adaptive Routing Technology
14.4 cm x 14.4 cm x 6.4 cm
Android 4.3 or later, Apple iOS 8.0 or higher
3-year warranty
Wi-Fi system - mesh
3 routers
Up to 6,750 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2134 Mbps
PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
Encryption Algorithm
WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC2200
Mesh Networking
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
8
External power adapter
Installed Qty
3
Network cable
14.4 cm
14.4 cm
6.4 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Wi-Fi system
Connectivity: Wired
Connectivity: Wireless
Speed: 2134Mbps
Protocol: Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11n
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: Fast Ethernet
Protocol: Bluetooth 4.2
Compatibility: Apple iOS
Antennas: 8
Brand: TP LINK
