TP LINK M7450 300Mbps Mobile WiFi
Quicklinx: FCMNWS00 Mfr#: M7450
Type: Mobile Hotspot
Connection Type: [N/A]
Standards: IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11b + 1 more
Speed: 300Mbps
Rackmount or External: External
  • IEEE 802.11n
25 In Stock
£90.26 ex VAT
£108.31 inc VAT
The M7450 supports the 4G LTE network. This advanced technology merges the fragmented LTE band into a virtual wider band to increase the data rate, to provide fast 4G speeds. You can enjoy movies without interruption, downloading files in seconds, and smooth online gaming. The M7450 provides selectable dual band Wi-Fi. It can easily share a 4G/3G connection with many wireless devices like tablets, laptops, and mobile phones at the same time. With this convenient companion, you can share your Wi-Fi with your friends everywhere.
M7450 is equipped with a powerful battery. On its own, it can work effortlessly many hours at full capacity. M7450 can be recharged via a micro-USB cable connected to a laptop, portable charger or adapter for endless hours of 4G sharing. The smooth curves and elegant, compact design make the lightweight M7450 perfect for personal travel, business trips, outdoor activities, and everywhere else life takes you. The intuitive screen display of M7450 makes it easy to stay within your data budget and avoids going over the monthly data cap. The screen also displays other much more information of battery life, signal strength, Wi-Fi status, connected users and more.
  • Do more with a faster mobile connection
  • Share AC1200 Wi-Fi with several wireless devices simultaneously
  • Power to keep working all-day-long
  • Your perfect daily Wi-Fi partner
  • Advanced screen & menu for easy using
TP-Link M7450 - mobile hotspot - 4G LTE Advanced
Mobile hotspot
External
Max Transfer Rate
300 Mbps
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA, LTE, DC-HSPA+, LTE Advanced, FDD LTE, TDD LTE
Mobile Band
GSM 850/900/1800/1900 / UMTS 900/2100 / LTE 800/900/1800/2100/2300/2500/2600
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac - 1200 Mbps
3000 mAh - up to 15 hrs
Apple MacOS, Android, Apple iOS, Windows Phone, Microsoft Windows XP / Vista / 7 / 8 / 10
11.2 cm x 6.6 cm x 1.6 cm
Mobile hotspot
External
Built-in Devices
1.44-inch TFT LCD
Modem
Wireless
Max Transfer Rate
300 Mbps
Mobile Band
Antenna
Internal
Wireless
Data Transfer Rate
1200 Mbps
Network / Transport Protocol
DHCP
MAC address filtering, Wi-Fi Protected Setup (WPS), DHCP server, reset button, DHCP client
Supported Flash Memory Cards
microSD, microSDHC
SIM Card Supported
Micro-SIM x 1
1 x USB power cable
Nano to Micro SIM Card adapter
Encryption Algorithm
WPA-PSK, WPA2-PSK
RoHS
11.2 cm
6.6 cm
1.6 cm
35 °C
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 300Mbps
Brand: TP LINK
