The M7450 supports the 4G LTE network. This advanced technology merges the fragmented LTE band into a virtual wider band to increase the data rate, to provide fast 4G speeds. You can enjoy movies without interruption, downloading files in seconds, and smooth online gaming. The M7450 provides selectable dual band Wi-Fi. It can easily share a 4G/3G connection with many wireless devices like tablets, laptops, and mobile phones at the same time. With this convenient companion, you can share your Wi-Fi with your friends everywhere.
M7450 is equipped with a powerful battery. On its own, it can work effortlessly many hours at full capacity. M7450 can be recharged via a micro-USB cable connected to a laptop, portable charger or adapter for endless hours of 4G sharing. The smooth curves and elegant, compact design make the lightweight M7450 perfect for personal travel, business trips, outdoor activities, and everywhere else life takes you. The intuitive screen display of M7450 makes it easy to stay within your data budget and avoids going over the monthly data cap. The screen also displays other much more information of battery life, signal strength, Wi-Fi status, connected users and more.
Do more with a faster mobile connection
The M7450 supports the 4G LTE network. This advanced technology merges the fragmented LTE band into a virtual wider band to increase the data rate, to provide fast 4G speeds. You can enjoy movies without interruption, downloading files in seconds, and smooth online gaming. -
Share AC1200 Wi-Fi with several wireless devices simultaneously
The M7450 provides selectable dual band Wi-Fi. It can easily share a 4G/3G connection with many wireless devices like tablets, laptops, and mobile phones at the same time. With this convenient companion, you can share your Wi-Fi with your friends everywhere. -
Power to keep working all-day-long
M7450 is equipped with a powerful battery. On its own, it can work effortlessly many hours at full capacity. M7450 can be recharged via a micro-USB cable connected to a laptop, portable charger or adapter for endless hours of 4G sharing. -
Your perfect daily Wi-Fi partner
The smooth curves and elegant, compact design make the lightweight M7450 perfect for personal travel, business trips, outdoor activities, and everywhere else life takes you. -
Advanced screen & menu for easy using
- TP-Link M7450 - mobile hotspot - 4G LTE Advanced
- Mobile hotspot
- Form Factor
- External
- Max Transfer Rate
- 300 Mbps
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSPA, LTE, DC-HSPA+, LTE Advanced, FDD LTE, TDD LTE
- Mobile Band
- GSM 850/900/1800/1900 / UMTS 900/2100 / LTE 800/900/1800/2100/2300/2500/2600
- Networking
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac - 1200 Mbps
- Battery
- 3000 mAh - up to 15 hrs
- System Requirements
- Apple MacOS, Android, Apple iOS, Windows Phone, Microsoft Windows XP / Vista / 7 / 8 / 10
- 11.2 cm x 6.6 cm x 1.6 cm
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- 1.44-inch TFT LCD
Modem
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 300 Mbps
- Mobile Band
- Antenna
- Internal
- Wireless
- Data Link Protocol
- Data Transfer Rate
- 1200 Mbps
- DHCP
- MAC address filtering, Wi-Fi Protected Setup (WPS), DHCP server, reset button, DHCP client
- Supported Flash Memory Cards
- microSD, microSDHC
- SIM Card Supported
- Micro-SIM x 1
- Cables Included
- 1 x USB power cable
- Included Accessories
- Nano to Micro SIM Card adapter
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- RoHS
- Capacity
- OS Required
- 11.2 cm
- 6.6 cm
- 1.6 cm
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
