TP LINK LTE-Advanced Mobile Wi-Fi
Quicklinx: D7GVWS00 Mfr#: M7350 V4
Type: Mobile Hotspot
Connection Type: [N/A]
Standards: IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11b + 1 more
Speed: 150Mbps
Rackmount or External: External
  • IEEE 802.11n
13 In Stock
£58.05 ex VAT
£69.66 inc VAT
TP-LINK's M7350 is at the forefront of wireless 4G sharing. Just insert a 4G SIM card into the device to instantly establish a selectable dual band Wi-Fi hotspot. With up to 150 Mbps download and 50 Mbps upload speeds, the M7350 is able to provide 4G wireless sharing to up to 15 users simultaneously. Its pocket-sized design and powerful 2550 mAh internal battery make it an ideal travel companion, allowing users to work or play for long hours. With its innovative TFT-display, users can have a much more intuitive view of the device's operating status, such as signal strength, network type (4G/3G/2G), Wi-Fi status, messages, Internet, traffic statistics and battery life.
  • 4G LTE - the faster connections, the more you can do
    Supporting the generation 4G LTE network, the M7350 can reach up to 150 Mbps download speeds, to enjoy HD movies without interruption, download files in seconds, and hold a video chat without dropouts.
  • Easily share dual band Wi-Fi with up to 15 devices
    Plug and Play, just insert a 4G SIM card to create your reliable personal 300 Mbps dual-band Wi-Fi hotspot on the move. Instantly share 4G/3G connectivity with up to 15 Wi-Fi enabled devices - tablets, mobile phones, laptops, game consoles and more.
  • Artful little gadget for life on the go
    The M7350 features a compact, elegant design very suitable for travel, business trips, outdoor activities or wherever you may be.
  • Long hours of 4G sharing - made to move
    With its powerful battery, the M7350 is able to operate for long hours at full capacity. For added flexibility, the device can be recharged via a micro USB cable connected to a laptop, portable charger or using its included adapter for endless hours of 4G sharing.
  • All useful info at a glance
    The intuitive screen display makes it easy to stay within your data budget and avoids going over the monthly data cap. With the menu button you can quickly change network type, data roaming and frequency band, view password and network name - directly on the device.
  • Micro SD card wireless sharing
    You can easily share photos, music, videos and more wirelessly across your network from a micro SD card though the micro SD storage slot.
TP-Link M7350 - V4 - mobile hotspot - 4G LTE
Mobile hotspot
External
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA, LTE, DC-HSPA+
Mobile Band
GSM 850/900/1800/1900 / UMTS 900/2100 / LTE 800/900/1800/2100/2600
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
2000 mAh - up to 8 hrs
Apple MacOS, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Windows 10
10.6 cm x 6.6 cm x 1.6 cm
Mobile hotspot
External
Built-in Devices
Display
Modem
Wireless
Max Transfer Rate
150 Mbps
Mobile Band
Antenna
Internal
Wireless
MAC address filtering, DHCP server, DHCP client
Supported Flash Memory Cards
microSD
1 x USB
SIM Card Supported
Regular (mini-SIM) x 1
1 x micro-USB cable
Encryption Algorithm
WPA-PSK, WPA2-PSK
RoHS
10.6 cm
6.6 cm
1.6 cm
35 °C
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 150Mbps
Brand: TP LINK
