TP LINK LiteWave 8-Port Gigabit Desktop Switch
Quicklinx: FT8JWS00 Mfr#: LS108G
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 8Gbps
Managed: No
POE: No
10 In Stock
£17.46 ex VAT
£20.95 inc VAT
The TP-Link LiteWave switches provide easy and affordable way to expand your wired network. They are easy to use and reliable.
Plug and play, no configuration needed
Fanless design ensures quiet operation
  • Durable metal casing
    The interior components of LS108G are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, LS105G delivers switching performance you can depend on. Its compact size makes it ideal for deployment on desktops or work benches.
  • Use where you need
    The LS108G is fully compatible with networked devices such as computers, printers, webcams, IPTVs. It has a wide range of application scenarios and is suitable for networking in school dormitories, surveillance, homes, and small businesses.
TP-Link LiteWave LS108G - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Forwarding performance: 11.9 Mpps
MAC Address Table Size
4K entries
Jumbo Frame Support
16KB
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, QoS, fanless, loop prevention
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
AC 220 V (50 Hz)
15.8 cm x 9.91 cm x 2.5 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
4K entries
Jumbo Frame Support
16KB
Status Indicators
Port status, power
8 x 1000Base-T RJ-45
External power adapter
AC 220 V (50 Hz)
3.7 watt
FCC, RoHS
15.8 cm
9.91 cm
2.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 8
Managed: No
POE: No
Brand: TP LINK
