TP LINK LiteWave 8-Port Gigabit Desktop Switch
Quicklinx: FT8MWS00 Mfr#: LS1008G
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 10Gbps
Managed: No
POE: No
More than 50 In Stock
£13.07 ex VAT
£15.68 inc VAT
The TP-Link LiteWave Series Unmanaged Switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these plug-and-play switches, you can expand your network connections to multiple devices instantly. With all ports support Auto-MDI/MDIX, there's no need to worry about the type of cable to use.
Increase the speed of your network with the LS1008G 8-port Gigabit desktop switch. Non-blocking, 8× 10/100/1000Mbps ports enable instant transferring of large, bandwidth intensive files without interference.
  • Go green with your Ethernet
    The LiteWave Series also supports energy-efficient technology, helping you save power and money. Power consumption automatically adjusts according to link status and cable length, allowing you to expand your network while minimizing your carbon footprint. Save the planet and lower your energy bills - it's a win-win!
  • Gigabit ports for faster speeds
  • Use where you need, however you need
    The LS1008G is fully compatible with networked devices such as computers, printers, webcams, IPTVs. It has a wide range of application scenarios and is suitable for networking in school dormitories, surveillance, homes, and small businesses.
TP-Link LiteWave LS1008G - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 10 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
4K entries
Jumbo Frame Support
16KB
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, plastic housing, fanless, Green Technology
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x
12.7 cm x 6.65 cm x 2.3 cm
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
4K entries
Jumbo Frame Support
16KB
Status Indicators
Power, link/activity
8 x 1000Base-T RJ-45
External power adapter
3.9 watt
FCC, RoHS
12.7 cm
6.65 cm
2.3 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 8
Managed: No
POE: No
Brand: TP LINK
