TP LINK LiteWave 8-Port 10/100M Desktop Switch
Quicklinx: FT8PWS00 Mfr#: LS1008
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 1167Mbps
Managed: No
POE: No
£7.33 ex VAT
£8.79 inc VAT
The TP-Link LiteWave Series Unmanaged Switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these plug-and-play switches, you can expand your network connections to multiple devices instantly. With all ports support Auto-MDI/MDIX, there's no need to worry about the type of cable to use.
The LiteWave Series also supports energy-efficient technology, helping you save power and money. Power consumption automatically adjusts according to link status and cable length, allowing you to expand your network while minimizing your carbon footprint. Save the planet and lower your energy bills - it's a win-win!
The LS1008 is fully compatible with networked devices such as computers, printers, webcams, IPTVs. It has a wide range of application scenarios and is suitable for networking in school dormitories, surveillance, homes, and small businesses.
  • Let LiteWave bring you lighter network life
  • Go green with your Ethernet
  • Fanless and desktop design
    Compact desktop design, to meet your needs in any environment. Besides, fanless design ensures quiet operation.
  • Use where you need, however you need
TP-Link LiteWave LS1008 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
Switching capacity: 1.6 Gbps , Forwarding performance: 1.2 Mpps
MAC Address Table Size
2K entries
Jumbo Frame Support
2000 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, plastic housing, fanless, Back Pressure Support, Green Technology
IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
12.46 cm x 4.87 cm x 2.28 cm
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
2K entries
Jumbo Frame Support
2000 bytes
Status Indicators
Power, link/activity
8 x 100Base-TX RJ-45
External power adapter
Power Provided
5 V - 0.6 A
2.64 Watt
Plug and Play, RoHS
12.46 cm
4.87 cm
2.28 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 8
Managed: No
POE: No
Brand: TP LINK
