TP LINK LiteWave 5-Port Gigabit Desktop Switch
Quicklinx: FT8KWS00 Mfr#: LS105G
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: No
12 In Stock
£9.88 ex VAT
£11.85 inc VAT
The TP-Link LiteWave switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these switches, you can expand your network connections to multiple devices instantly.
  • Durable metal casing
    The interior components of LS105G are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, LS105G delivers switching performance you can depend on.
  • Use where you need
    The LS105G is fully compatible with networked devices such as computers, printers, webcams, IPTVs. It has a wide range of application scenarios and is suitable for networking in school dormitories, surveillance, homes, and small businesses.
TP-Link LiteWave LS105G - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Forwarding performance: 7.4 Mpps
MAC Address Table Size
2K entries
Jumbo Frame Support
16KB
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, QoS, fanless, loop prevention
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
AC 220 V (50 Hz)
9.98 cm x 9.8 cm x 2.5 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
2K entries
Jumbo Frame Support
16KB
Status Indicators
Port status, power
5 x 1000Base-T RJ-45
External power adapter
AC 220 V (50 Hz)
2.776 Watt
FCC, RoHS
9.98 cm
9.8 cm
2.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 5
Managed: No
POE: No
Brand: TP LINK
