The TP-Link LiteWave switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these switches, you can expand your network connections to multiple devices instantly.
Durable metal casing
The interior components of LS105G are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, LS105G delivers switching performance you can depend on. -
Use where you need
The LS105G is fully compatible with networked devices such as computers, printers, webcams, IPTVs. It has a wide range of application scenarios and is suitable for networking in school dormitories, surveillance, homes, and small businesses.
 - TP-Link LiteWave LS105G - switch - 5 ports - unmanaged
 - Switch - 5 ports - unmanaged
- Subtype
 - Gigabit Ethernet
- Ports
 - 5 x 10/100/1000
- Performance
 - Forwarding performance: 7.4 Mpps
- MAC Address Table Size
 - 2K entries
- Jumbo Frame Support
 - 16KB
 - Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, QoS, fanless, loop prevention
 - IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
- Power
 - AC 220 V (50 Hz)
 - 9.98 cm x 9.8 cm x 2.5 cm
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - 5 x 10/100/1000
- Performance
 - 2K entries
 - 16KB
- Status Indicators
 - Port status, power
 - 5 x 1000Base-T RJ-45
- Power Device
 - External power adapter
- Voltage Required
 - AC 220 V (50 Hz)
 - 2.776 Watt
 - FCC, RoHS
 - 9.98 cm
 - 9.8 cm
 - 2.5 cm
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 90% (non-condensing)
