Control your lighting from anywhere with the LB120. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used.
The LB120 also lets you tune its white temperature to create lighting suited to your mood, from bright daylight to soft, relaxing whites. For added convenience, you can control the LB120 with your voice when paired with Amazon Alexa.
Highlights:
* Control your lights from anywhere with your tablet or smartphone using the free Kasa app (iOS, Android)
* Dim brightness and fine-tune light appearance from soft white (2700k) to daylight (6500k)
* Pair to Amazon Alexa and to enable voice control
* Automatically matches light appearance to time of day
* Track real-time energy used to stay informed
Package Contents:
* Smart Wi-Fi LED Bulb LB120
* Quick Installation Guide
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
Manage remotely
Control your lights from anywhere with your tablet or smartphone, using the app. -
Fine-tune lighting
Dim brightness and fine-tune light appearance from soft white to daylight. -
Circadian mode
Automatically matches light appearance to time of day. -
Monitor power
Track real-time energy used to stay informed. -
Save energy
Reduce energy use without brightness or quality loss.
- TP-Link LB120 - LED light bulb - frosted finish - E27 - 10 W - warm white/daylight - 2700-6500 K
- Light Source Type
- LED light bulb
- Usage Modes
- Anti burglar
- Bulb Finish
- Frosted
- Socket Type
- E27
- Wattage
- 10 W
- Wattage Equivalent
- 60 W
- Colour of Illumination
- Warm white/daylight
- Colour Temperature
- 2700-6500 K
- Luminous Power
- 800 lumens
- Beam Angle
- 180 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa
- Voltage Required
- AC 120 V
- Frequency Required
- 60 Hz
- Usage Modes
- Anti burglar
Light Source
- LED light bulb
- Bulb Finish
- Frosted
- Socket Type
- E27
- Wattage
- 10 W
- 60 W
- 2700-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 800 lumens
- Beam Angle
- 180 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Android compatible, iOS compatible, Circadian mode, voice control, controlled via Wi-Fi
Power Requirements
- Voltage Required
- AC 120 V
- 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- UL, FCC, RoHS
- 170 g
- -15 °C
- 40 °C
