Cut down electric bills
Monitor your connected devices' real-time energy consumption and learn which ones use the most power. Reduce unnecessary energy loss and lower your electric bills with the schedule and timer. -
Hands-free voice control
Simple voice commands let you turn off your lights when your hands are full. Just pair your smart plug with Alexa, Google Assistant, or Samsung SmartThings for enjoyable ease. -
Set a schedule and timer for convenience
Easily create a worry-free schedule for your appliances any day of the week following your daily routine. Automatically turn off your bedside lamp when you are about to fall asleep. -
Control from anywhere, anytime
Not sure whether you switched your fan off after leaving home? Double check and control it remotely on your phone or tablet to save energy and avoid electrical hazards. -
Space-saving design
Compared with the older Kasa energy monitoring plug, HS110, this plug is smaller, leaving adjacent sockets free. -
Away mode
Improve your home security by turning your electrical devices, like lamps, on and off at random intervals to give the appearance that you're home even while you're away. -
Group Control
Use Group Control to combine your smart plug with other Kasa Smart devices for seamless control with a single tap on your phone. -
App-guided easy setup
Plug in the smart plug, follow the setup instructions on the Kasa Smart app, name it, and you're good to go!
- Kasa Smart KP115 V1 - smart plug - 802.11b/g/n
- Product Type
- Smart plug
- Functions
- Energy use monitor, turn electronics on/off
- Internet of Things (IoT) Platform
- Google Home, SmartThings
- Intelligent Assistant
- Alexa
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- 5.15 cm x 3.75 cm x 7.25 cm
- Product Type
- Smart plug
- Functions
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- OS Required
- Android 5.0 or later, Apple iOS 10 or later
- Interfaces Details
- Power input
- Child protection, voice control, LED indicator, automatically lighting schedule replaying, overheat protection, flame-retardant
- Platform
- Alexa
- Product Material
- Flame retardant plastic
- Nominal Voltage
- AC 100 - 240 V
- Rated Current
- 13 A
- RoHS, PC UL94 V0
- 5.15 cm
- 3.75 cm
- 7.25 cm
- 90 g
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
