TP LINK KL130 Multicolour Smart Bulb - Screw
Quicklinx: F2Q9WS00 Mfr#: KL130
Type: Light bulb
Compatible With: Alexa, Cortana, Google Assistant
£14.99 ex VAT
£17.98 inc VAT
Express delivery Order within the next 17 hours for delivery on Monday
Kasa Smart Light Bulb, Multicolor
Multicolor – With a wide range of colors and dimming capabilities, Kasa Smart’s multicolor light bulb offers endless lighting possibilities. You can choose a light for everything from a dinner party to a late-night study session.
No Hub Required – Kasa Smart’s multicolor light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere – Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
Voice Control - Use simple voice commands to control your Kasa Smart multicolor light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Have your voice assistant change the color to help you wake up in the morning or adjust the brightness to help your kids settle down in the evening.
Auto White – Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules – Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
Energy Consumption Class A+ – Kasa Smart's multicolor light bulb is certified to drive down energy consumption without losing quality.
Add Color to Your Life
Create the perfect ambiance with your Kasa Smart multicolor light bulb.
Multicolor
Schedules
Control your smart light bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Smoothly dim the brightness of your light bulb from anywhere with the app.
Scenes
You like your light bright while they like it dim — but you both hate adjusting every bulb each time. Solve both problems with Kasa Smart. Create multiple scenes with different settings and tap yours when you want the light your way.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
  • Multicolor
    With a wide range of colors and dimming capabilities, Kasa Smart's multicolor light bulb offers endless lighting possibilities. You can choose a light for everything from a dinner party to a late-night study session.
  • No hub required
    Kasa Smart's multicolor light bulb connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
  • Control from anywhere
    Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app. Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
  • Voice control
  • Auto white
  • Scenes and schedules
    Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you're home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
TP-Link KL130 - LED light bulb
Light Source Type
LED light bulb
Shape
A19
Socket Type
E26
Wattage
10.5 W
Wattage Equivalent
60 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Multicolour light
Colour Temperature
2500-9000 K
Luminous Power
800 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa
Platform
Kasa
Communications Technology
Wi-Fi
AC 120 V
Frequency Required
50/60 Hz
Warranty
2 year warranty
Light Source
LED light bulb
Shape
A19
Socket Type
E26
Wattage
10.5 W
Wattage Equivalent
60 W
A+
Multicolour light
Colour Temperature
2500-9000 K
Luminous Power
800 lumens
Beam Angle
220 degree(s)
Dimmable
Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled
Power Requirements
AC 120 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Hub
Not needed
Platform
Kasa
Wi-Fi
Intelligent Assistant Compatible
UL, FCC, CEC, DOE, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Warranty
3 years
118 mm
Diameter
60 mm
139 g
-15 °C
Type: Light bulb
Compatible With: Cortana
Brand: TP LINK
Price Range Ex VAT: 0 - 50
