TP LINK KL110 Dimmable Kasa Smart Bulb - Screw
Quicklinx: F1KFWS00 Mfr#: KL110
Type: Light bulb
Compatible With: Alexa, Cortana, Google Assistant
£13.89 ex VAT
£16.66 inc VAT
Kasa Smart Wi-Fi Light Bulb, Dimmable
Control the mood with your Kasa Smart dimmable light bulb.
Dimmable
With a dimming range from 1% up to 100%, the Kasa Smart Wi-Fi Light Bulb, Dimmable helps you set the right brightness for any mood or activity.
Grouping
Use the Grouping feature on the Kasa Smart app to combine your devices together for unified control with one single tap on your smartphone. Combine your living room bulbs, plugs and light switches together for an easier way to turn them on when you get home.
Control From Anywhere
Control your Kasa Smart lighting from anywhere with the highly-rated Kasa Smart app (available for iOS, Android). Make sure you turned your bedroom lights off from the office or turn your living room lights on before you get home.
Voice Control
Use simple voice commands to control all of your Kasa Smart light switches or light bulbs with any Alexa, Google Assistant or Microsoft Cortana smart speaker. Turn on kitchen lights when your hands are full, let your voice assistant know to dim your lights, even turn off hallway lights as you're walking to bed.
No Hub Required
Connect your Kasa Smart dimmable light bulb directly to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Energy Efficient
The Title 20 and Energy Star certified light bulb reduces consumption by up to 80% without losing brightness or quality, while saving you money.
  • Dimmable
    Kasa Smart's dimmable light bulb has a dimming range from 1% to 100%. Set the right brightness for any mood or activity. Turn your bulb to full brightness to get your kids up in the morning or dim it enough for them to fall asleep at night.
  • No hub required
    The Kasa Smart Wi-Fi Light Bulb, Dimmable connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
  • Control from anywhere
    Control your smart light bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Smoothly dim the brightness of your light bulb from anywhere with the app.
  • Voice control
    Use simple voice commands to control your Kasa Smart dimmable light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
  • Scenes and schedules
    Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you're home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Dim all your lights and set the scene for a romantic dinner or a movie night.
  • Energy efficient
TP-Link KL110 - LED light bulb
Light Source Type
LED light bulb
Shape
A19
Socket Type
E26
Wattage
10 W
Wattage Equivalent
60 W
Colour of Illumination
White light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa
Platform
Kasa
Communications Technology
Wi-Fi
AC 120 V
Frequency Required
50/60 Hz
Warranty
2 year warranty
Light Source
LED light bulb
Shape
A19
Socket Type
E26
Wattage
10 W
Wattage Equivalent
60 W
White light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
220 degree(s)
Dimmable
Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled
Power Requirements
AC 120 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Platform
Kasa
Wi-Fi
Intelligent Assistant Compatible
UL, FCC, CEC, DOE
Warranty
3 years
118 mm
Diameter
60 mm
134 g
88 mm x 72 mm x 150 mm
-15 °C
Type: Light bulb
Compatible With: Cortana
Brand: TP LINK
