TP LINK KC105 Kasa Smart Spot Cam with microSD slot
Quicklinx: FX5LWS00 Mfr#: KC105
  • microSDHC Card
  • microSD Card
£33.33 ex VAT
£39.99 inc VAT
Keep an eye on your things with Kasa Spot indoor security camera. Receive instant alerts through Kasa app when your camera detects motion or sound activity. With all videos stored locally on MicroSD card, access your video history and live stream 1080p HD video on your smartphone, an Alexa or Google Assistant supported display.
  • Secure local storage
    Save your footage on a Micro SD card and play back with your Kasa Smart app.
  • Real-time alerts
    No need to check your Kasa Spot throughout the day. Get automatic alerts when it detects motion or sound.
  • Two-way audio
    Use crisp two-way audio to communicate with unexpected visitors.
  • Activity zones
    Configure up to 4 customizable zones to receive alerts you care about.
  • Live view
    Keep an eye on what's important to you in real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display.
TP-Link Kasa Spot KC105 - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.9 cm x 4.96 cm x 8.86 cm
198 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
1/2.7"
Focal Length Control
Fixed focal
Focal Length
3.21 mm
Lens Iris
F/2.0
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa ready, Google Assistant ready
1 - USB cable - external - 3.05 m
Voltage
DC 5 V
Push Notification, reset button, Smartphone Monitoring, Audio Detection, WPA, WPA2-PSK, WEP
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Audio Formats
AAC
Wireless
5.9 cm
4.96 cm
8.86 cm
198 g
Camera
Colour - Day&Night - fixed - indoor
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
6.1 m
Video Capture
1920 x 1080 @ 15 fps
Image Sensor
1/2.7"
Lens Construction
Fixed focal
Focal Length
3.21 mm
Lens Iris
F/2.0
Network Interface
Network Protocols
TLS, SSL
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Template, screw kit
1 x USB cable - external - 3.05 m
IC, FCC, AES-128
Power Requirements
DC 5 V - 1 A
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 (KitKat) or later, Apple iOS 9 or later
Internet of Things (IoT)
Supported Host Device Platform
iOS, Android
Relative Humidity (operating)
Type: Indoor Camera
Compatible With: Alexa ready
Compatible With: Google Assistant ready
Brand: TP LINK
