Kasa Spot - KC100
Keep an eye on your things with Kasa Smart Spot, an HD indoor security camera.
Crystal Clear Video
Sharp and clear 1080p full-HD provides high-quality video right in the palm of your hand.
Wide Angle Field Of View
The Spot's 130°, wide-angle field of view makes sure nothing is out of view. Set it up in a corner and get a full view of your living room or place it on top of a shelf to get a great view of your kitchen.
Instant Activity Alerts
No need to check your Kasa Spot throughout the day. Get automatic alerts when your Spot detects motion or sound.
Night Vision
Even in the dark, the Kasa Spot has Night Vision up to 20 feet. Never miss a thing at night and still get the same high-quality video you’re used to.
Two-way Audio
Use crisp two-way audio to communicate with nosy roommates, family or even mischievous pets.
Activity Zones
Configure up to 4 customizable zones for more meaningful alerts at no cost to you. Place zones around your front door, kitchen or anywhere you like to focus your camera’s view.
24/7 Live View
Keep an eye on what’s important to you real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV, Echo Show or Chromecast.
Motion snapshots
Kasa Smart Spot will send you an alert when motion is detected and save the activity as a snapshot. -
Clear video
HD, wide-angle video and night vision, make sure you never miss a thing day or night. -
Activity zones
Create multiple activity zones around areas that are important and receive alerts you care about. -
Two-way talk
Communicate with others with the built-in microphone and speaker.
- Kasa Smart Spot - network surveillance camera
- Network surveillance camera - fixed - indoor
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 5.89 cm x 4.95 cm x 8.86 cm
- 68 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 15 frames per second
- Motion Detection
- Video Modes
- 1080p
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Intelligent Assistant
- Alexa ready, Google Assistant ready
- Cables Included
- 1 - USB cable - external - 3.05 m
- Voltage
- DC 5 V
- Audio Detection, activity detection
- 2-year warranty
- Audio Support
- Wireless
- 5.89 cm
- 4.95 cm
- 8.86 cm
- 68 g
Camera
- Colour - Day&Night - fixed - indoor
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 6.1 m
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
Lens Construction
- Horizontal Field of View (degree)
- 130
- Network Interface
- Network Protocols
- TLS, SSL
- Included Accessories
- Template, screw kit
- Cables Included
- 1 x USB cable - external - 3.05 m
- Power Requirements
- DC 5 V - 1 A
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz)
- OS Required
- Android 4.4 (KitKat) or later, Apple iOS 10 or later
Internet of Things (IoT)
- Limited warranty - 2 years
- Shipping Width
- 16.45 cm
- Shipping Depth
- 8.15 cm
- Shipping Height
- 14.25 cm
