TP LINK Kasa Plug and Bulb Pack - KP105 + KL110
Quicklinx: FX3LWS00 Mfr#: KasaTwinPack-E27
Includes KP105 Kasa Smart Socket and KL110 Kasa Smart Bulb E27
KP105 Kasa Smart Wi-Fi Plug Slim
Control from Anywhere – Remotely control your connected devices on your smartphone.
Compact Design – Fits into sockets without blocking adjacent ones.
Voice Control – Free up your hands with simple voice commands. Works with Alexa, Google Home, and Bixby.
Schedule and Timer – Set a schedule or timer to switch your devices on or off automatically.
Multiple Safety Guarantees – Overheating protection and PC flame retardant material help minimize burning hazards. A sliding safety cover protects children from electric shock.
Grouping – Use Grouping to combine all 3 of your smart plugs on the power strip with other Kasa Smart devices for seamless control with one single tap on your smartphone.
Smart Actions – Enable device interconnections and home automation for your Kasa devices. There are three types of Actions that can be created: "Motion Sensing", "Schedule a Scene" and "Auto-off Timer".
KL110 Kasa Smart Light Bulb, Dimmable
Dimmable – Kasa Smart’s dimmable light bulb has a dimming range from 1% to 100%. Set the right brightness for any mood or activity. Turn your bulb to full brightness to get your kids up in the morning or dim it enough for them to fall asleep at night.
No Hub Required – The Kasa Smart Wi-Fi Light Bulb, Dimmable connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere – Control your smart light bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Smoothly dim the brightness of your light bulb from anywhere with the app.
Voice Control - Use simple voice commands to control your Kasa Smart dimmable light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
Scenes and Schedules – Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you're home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Dim all your lights and set the scene for a romantic dinner or a movie night.
Energy Consumption Class A+– Kasa Smart's dimmable light bulb is certified to drive down energy consumption without losing quality.
Grouping – Combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap on your smartphone.
  • Hands-free voice control
    Connect your smart plug with Amazon Alexa, Google Assistant, and SmartThings, and control connected devices by only using your voice.
  • Simple to set up and use with Alexa
    Setup is faster than ever before with Alexa. Use your Echo device to set up the plug via voice command.
  • Remote access
    Control devices connected to the smart plug wherever you have internet using the free Kasa app on your smartphone.
  • Scheduling
    Set schedules with the Kasa Smart app to automatically turn your smart plug on or off while you're away.
  • Easy setup
    Download the Kasa Smart app and follow the setup instructions for your plug.
Kasa Smart KP105 V1 - smart plug - 802.11b/g/n
Smart plug
Functions
Turn electronics on/off
Internet of Things (IoT) Platform
Google Home, SmartThings
Intelligent Assistant
Alexa, Bixby
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
5.15 cm x 3.75 cm x 7.25 cm
Smart plug
Functions
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Android 5.0 or later, Apple iOS 10 or later
Interfaces Details
Power input
Child protection, voice control, overheat protection, flame-retardant, up to 13 A
Platform
Alexa, Bixby
Product Material
Polycarbonate
Nominal Voltage
AC 100 - 240 V
Warranty
RoHS
5.15 cm
3.75 cm
7.25 cm
90 g
5 - 90% (non-condensing)
