TP LINK Kasa KE100KIT Smart Valve + KH100 IoT Hub
Quicklinx: H43TWS00 Mfr#: KE100KIT
Type: Radiator thermostat
Compatible With: Google Assistant, Alexa
£33.33 ex VAT
£39.99 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
• When in use with Tapo T110 Contact Sensor *(and connected to the same wireless hub), KE100KIT / KE100 can automatically turn off the heating when an open window or door is detected. Frost protection can also be activated. (Tapo T110 purchased separately).
• When in use with Tapo T310 / T315 Temperature Sensor *(and connected to the same wireless hub), KE100KIT / KE100 can automatically regulate the temperature, in accordance with the information provided by the temperature sensor. (Tapo T310 & T315 purchased separately).
Precise Temperature Control - Get the right temperature whenever you want it.
Schedule & Timer - Make sure it is as hot as you need with presets and schedules that suit your life.
Voice Control - Hands-free control that syncs with Amazon Alexa, Google Assistant, or Siri ShortCuts.
Frost Protection - Keep your pipes unfrozen and your house safe.
Ultra-Long Standby - Works with lot hub, promising longer battery life (over one year).
Up to 32 Radiators – Each hub can connect and manage up to 32 radiators.
Versatile Compatibility – Fits on most radiator valve body thread (M30x1.5) and the three adapters(RA, RAV & RAVL) included allow more compatibility.
Hub Included - Simply replace your old radiator valve with Kasa and get started right away.
Room-by-Room Comfort - Set the perfect temperature for each room individually to maximize comfort in the whole house
Control from Anywhere - Control all your radiators in your home from your phone. No more guessing if you left the heater on in an empty room.
Compatibility -Fits on most radiator valve body thread (M30x1.5) and three adapters given to allow more compatibility.
Child Lock - Prevent children from managing your radiator accidentally.
In the box
  • 1× KE100
  • 1× KH100
  • 2× AA/LR6 batteries
  • 1× Quick Start Guide
  • 1× RA adapter
  • 1× RAV adapter
  • 1× RAVL adapter
  • 1× Cover Opener
Smart Radiator Valve: 868 MHz
Smart radiator value 868 MHz, Kasa Hub 2.4GHz Wi-Fi, 868Mhz
Compatible With: Alexa
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
