TP LINK Kasa KE100 add on Smart Radiator Valve
Quicklinx: H43VWS00 Mfr#: KE100
Type: Radiator thermostat
Compatible With: Google Assistant, Alexa
More than 50 In Stock
£29.99 ex VAT
£35.98 inc VAT
• When in use with Tapo T110 Contact Sensor *(and connected to the same wireless hub), KE100KIT / KE100 can automatically turn off the heating when an open window or door is detected. Frost protection can also be activated. (Tapo T110 purchased separately).
• When in use with Tapo T310 / T315 Temperature Sensor *(and connected to the same wireless hub), KE100KIT / KE100 can automatically regulate the temperature, in accordance with the information provided by the temperature sensor. (Tapo T310 & T315 purchased separately).
Remote Control - Control all your radiators in your home from your phone. No more guessing if you left the heater on in an empty room.
Vocie Control - Ask Alexa or Google Assistant to fine-tune your home’s temperature.
Smart Schedule - Set heating schedules based on your daily routines to make heating more efficient.
Frost Protection - Keep your pipes unfrozen and your house safe.
Child Lock - Prevent children from managing your radiator accidentally.
Install It Yourself - Simply replace your old radiator valve with Kasa and follow the step-by-step in-app guide for installation.
Hub Required - Kasa Hub KH100 is required for all smart features.
Precise Temperature Control - Kasa Smart Thermostatic Radiator Valve provides superior temperature precision from the moment it is installed. Get the exact temperature you set. Nothing more. Nothing less.
Control from Anywhere - Control all your radiators in your home from your phone. No more guessing if you left the heater on in an empty room.
Room-by-Room Comfort - Set the perfect temperature for each room individually to maximize comfort in the whole house. Each hub can manage up to 32 radiators.
Quick & Easy Installation - Install it yourself with our step-by-step guide. Two AA batteries can easily last through an entire heating season.
Compatibility - Fits on most radiator valve body thread (M30x1.5) and three adapters given to allow more compatibility.
HUB REQUIRED
In the box
  • 1 × KE100
  • 2 × AA/LR6 batteries
  • 1 × Quick Start Guide
  • 1 × RA adapter
  • 1 × RAV adapter
  • 1 × RAVL adapter
  • 1 × Cover Opener
Compatible With: Alexa
Brand: TP LINK
