TP LINK JetStream TL-SL1218P - V1 Switch - 16 ports - Unmanaged - Rack-Mountable
Quicklinx: FZ6GWS00 Mfr#: TL-SL1218P
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
Hurry, only 2 left in stock!
£112.96 ex VAT
£135.55 inc VAT
The TL-SL1218P is fully compatible with PoE devices, such as IP cameras, access points, and IP phones. It also works with non-PoE wired devices, such as PCs, printers, and IPTV.
TP-Link JetStream TL-SL1218P - V1 - switch - 16 ports - unmanaged - rack-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100 (PoE+) + 2 x 10/100/1000 + 1 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
150 W
Performance
Switching capacity: 7.2 Gbps , Packet forwarding rate: 5.36 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Flow control, security lock slot (cable lock sold separately), 2 fans, priority mode, extend mode, Intelligent Power Management
IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
44 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
150 W
Performance
8K entries
Jumbo Frame Support
10KB
16 x 100Base-TX RJ-45 PoE+ - 30 W , 1 x 1000Base-T RJ-45 , 1 x 1000Base-T / 1000Base-X RJ-45/SFP
Internal power supply
172.8 Watt
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
44 cm
18 cm
4.4 cm
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 16
Managed: No
POE: PoE+
Brand: TP LINK
