TP LINK JetStream TL-SG2218 - V1 - switch - smart - 16 x 10/100/1000
Quicklinx: G6WYWS00 Mfr#: TL-SG2218
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
10 In Stock
£116.27 ex VAT
£139.52 inc VAT
  • Full Gigabit Ports: 16× gigabit RJ45 ports and 2× gigabit SFP Slots provide high-speed connections.
  • Integrated into Omada SDN: Zero-Touch Provisioning (ZTP), Centralised Cloud Management, and Intelligent Monitoring.
  • Centralised Management: Cloud access and Omada app for ultra convenience and easy management.
  • Static Routing: Helps route internal traffic for more efficient use of network resources.
  • Robust Security Strategies: IP-MAC-Port Binding, ACL, Port Security, DoS Defend, Storm control, DHCP Snooping, 802.1X, Radius Authentication, and more.
  • Optimize Voice and Video Applications: L2/L3/L4 QoS and IGMP snooping.
  • Standalone Management: Web, CLI (Telnet, SSH), SNMP, RMON, and Dual Image bring powerful management capabilities
  • Advanced L3 features
    An abundance of L2+ and L3 features are supported to help build a highly scalable and robust network, providing a reliable and efficient solution for enterprises, campuses and ISPs.
  • Secure networking
    Security features include IP-MAC-Port-VID Binding, Port Security, Storm Control and DHCP Snooping to defend against a range of network threats. An integrated list of common DoS attacks is available, making it easier than ever to prevent them. In addition, the Access Control Lists (ACL, L2 to L4) feature restricts access to sensitive network resources by denying packets based on source and destination MAC address, IP address, TCP/UDP ports or VLAN ID. Users' network access can be controlled via 802.1x authentication, which works with a RADIUS/Tacacs+ server to grant access only when valid user credentials are provided.
  • Enterprise-level features
    A complete lineup of L2+ features are supported, including 802.1Q VLAN, Port Mirroring, STP/RSTP/MSTP, Link Aggregation Control Protocol, and 802.3x Flow Control. Advanced IGMP Snooping ensures the switch intelligently forwards multicast streams to only the appropriate subscribers, cutting out unnecessary traffic, while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access. Static Routing is a simple way of segmenting the network and internally routs traffic through the switch for improved efficiency.
  • Advanced QoS
    Voice and video traffic can be prioritized based on IP address, MAC address, TCP port number, UDP port number, and more. With QoS (Quality of Service), voice and video services remain smooth, even when bandwidth is in short supply.
  • ISP features
    sFlow, QinQ, L2PT PPPoE ID Insertion and IGMP authentication features are provided, developed with service providers in mind. 802.3ah OAM and Device Link Detection Protocol (DLDP) offer easy monitoring and troubleshooting of Ethernet links.
  • IPv6 support
    IPv6 functions, such as Dual IPv4/IPv6 Stack, MLD Snooping, IPv6 ACL, DHCPv6 Snooping, IPv6 Interface, Path Maximum Transmission Unit (PMTU) Discovery and IPv6 Neighbor Discover, guarantee your network is ready for the Next Generation Network (NGN) without upgrading your hardware.
TP-Link JetStream TL-SG2218 - V1 - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 + 2 x SFP
Performance
Switching capacity: 36 Gbps , Forwarding rate: 26.78 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, DHCP, IPv4, IPv6
Flow control, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, bandwidth control, DLDP support, NDP, CoS, SP, GVRP, Storm Control, BPDU, Link Aggregation, AAA, Voice VLAN, IPMB, ZTP, WRR, loopback detection, 4.1Mbit packet buffer, MLD, DSCP prioritisation
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
44 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, TLS 1.2
Authentication Method
Secure Shell (SSH), RADIUS, PAP, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP), EAP-TLS, EAP-TTLS
RAM
256 MB
Flash Memory
32 MB
16 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP
Internal power supply
15.9 watt
Rack Mounting Kit
Included
FCC, RoHS
44 cm
18 cm
4.4 cm
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 16
Managed: Yes
POE: No
Brand: TP LINK
