The T2600G-28MPS provides 24 10/100/1000Mbps ports that support 802.3at/af-compliant PoE, with a total PoE power supply of up to 384W, giving users the power and flexibility to deploy wireless access points or IP-based network surveillance cameras. In addition, it provides high performance static routing, enterprise-level QoS, advanced security strategies and rich layer 2 management attributes. With all these advanced features, the JetStream Gigabit L2 Managed PoE Switch is an ideal choice for small and medium business networking solutions.
The switch provides high performance, powerful L2 and L2+ features like static routing, enterprise-level QoS and other advanced security strategies. OAM, L2PT and sFlow can meet the requirement of large ISP customers, and the IP-MAC-Port Binding and Access Control List (ACL) functions protect against broadcast storm, ARP and Denial-of-Service (DoS) attacks, etc. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Moreover, the easy-to-use web management interfaces, along with CLI, SNMP, RMON and Dual Image mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive L2 Switch and gigabit capability, TP-LINK JetStream 24-Port Gigabit L2 managed PoE+ Switch T2600G-28MPS provides you the ideal network solution.
IEEE 802.3at/af-compliant Power over Ethernet
The T2600G-28MPS supports 24 ports of IEEE 802.3at/af-compliant PoE and has a total power supply of 384W to power any 802.3at or 802.3af compliant power device. It's an efficient and cost-effective choice to work with wireless access points, surveillance cameras, IP phones and other PoE supported devices, while getting rid of cables or power lines running around. Compact and flexible, the T2600G-28MPS is ideal to flexibly use PoE to deploy wireless access points or IP-based network surveillance cameras for projects or small business networks. -
Secure networking
The T2600G-28MPS provides IP-MAC-Port Binding, Port Security, Storm control and DHCP Snooping which protect against broadcast storms, ARP attacks, etc. It integrates some typical DoS attacks to select. You can protect these attacks more easily ever than before. In addition, the Access Control Lists (ACL, L2 to L4) feature restricts access to sensitive network resources by denying packets based on source and destination MAC address, IP address, TCP/UDP ports and even VLAN ID. Moreover, the switch supports 802.1X authentication, which is used in conjunction with a RADIUS server to require some authentication information before access to the network is allowed. Guest VLAN function supports to enable the non-802.1X clients to access the specific network resource.
 - TP-Link JetStream T2600G-28MPS - switch - 24 ports - Managed - rack-mountable
 - Switch - 24 ports - L2+ - Managed
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000 (PoE+) + 4 x SFP
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 384 W
- Performance
 - Switching capacity: 56 Gbps , Forwarding performance: 41.7 Mpps
- Capacity
 - QoS hardware queues: 8 , VLANs supported: 4000
- MAC Address Table Size
 - 16K entries
- Jumbo Frame Support
 - 9216 bytes
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3, MLD
- Remote Management Protocol
 - SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
 - Flow control, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), Device Link Detection Protocol (DLDP) support, IPv4 support, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, IP-MAC binding, DHCP client, Neighbor Discovery Protocol (NDP), static routing, Loopback, Generic Attribute Registration Protocol (GARP), 802.1x authentication, GARP VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 1.5MB packet buffer, IP source guard, ARP inspection, Bridge protocol data unit (BPDU)
 - IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.3at
- Power
 - AC 120/230 V (50/60 Hz)
 - 44 cm x 33 cm x 4.4 cm
 - 6 kg
- System Requirements
 - UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
- Enclosure Type
 - Desktop, rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 384 W
- Performance
- Capacity
 - 16K entries
 - 9216 bytes
- Routing Protocol
- Encryption Algorithm
 - TLS 1.0, SSL 3.0
- Authentication Method
 - RADIUS, TACACS+
 - 24 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-X SFP , 1 x console RJ-45 , 1 x micro-USB output management
- Power Device
 - Internal power supply
- Voltage Required
 - 468.7 Watt
- Included Accessories
 - Rubber feet
- Rack Mounting Kit
 - Included
 - FCC, RoHS
- Software Included
 - Drivers & Utilities
- OS Required
 - 44 cm
 - 33 cm
 - 4.4 cm
 - 6 kg
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 5 - 90% (non-condensing)
