TP LINK JetStream 8-port Pure-Gigabit L2 Managed Switch
Quicklinx: FNDGWS00 Mfr#: T2500G-10TS(TL-SG3210)
Designed for workgroups and departments, T2500G-10TS provides full set of Layer 2 management features. It delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Gigabit switches and high-speed servers.
  • Abundant L2 features
    T2500G-10TS supports a complete lineup of L2 features. In addition, the switch provides advanced features for network maintenance. IGMP throttling & filtering restricts each subscriber on a port level to prevent unauthorized access.
  • Secure networking
    The T2500G-10TS provides advanced security to protect against broadcast storms, ARP attacks, and more. Moreover, the switch supports 802.1x authentication, which is used in conjunction with a RADIUS server to require some authentication information before access to the network is allowed.
  • Advanced QoS features
    To integrate voice, data and video service on one network, T2500G-10TS supports rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means, to ensure that voice and video are always clear, smooth and jitter free.
TP-Link JetStream T2500G-10TS - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x Gigabit SFP
Performance
Bandwidth: 20 Gbps , Packet forwarding rate: 14.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP, SSH, SSH-2, CLI
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, VCT technology, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, DAI, fanless, LACP, Port Security, IP-MAC binding, SNMP trap, GARP, GVRP
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.3av
29.4 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9KB
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
RADIUS
8 x 1000Base-T RJ-45 , 1 x console RJ-45 , 2 x 1000Base-X SFP , 1 x console (micro-USB)
Internal power supply
8.38 watt
Rubber feet
Rack Mounting Kit
Included
FCC
29.4 cm
18 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
