TP LINK JetStream 28-Port Gigabit Stackable L2+ Managed Switch
Quicklinx: BLZ6WS00 Mfr#: T2700G-28TQ
TP-LINK's T2700G-28TQ is an L2+ managed switch designed to build a highly accessible, scalable, and robust network. The switch is equipped with 24 Gigabit RJ-45 ports, 4 Combo Gigabit SFP and up to 4 10Gbps SFP slots, giving network administrator great network flexibility. It supports basic Layer3 features like static routing and RIP v1/v2 by default and can be upgraded to support abundant Layer 3 features such OSPF/ECMP/PIM/VRRP with the addition of a Layer3 license. T2700G-28TQ provides robust security to help secure your enterprise network. TP-LINK's T2700G-28TQ L2+ managed switch provides a reliable and cost-effective solution for enterprise, campus and ISP networks.
TP-Link JetStream T2700G-28TQ - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance: up to 95.2 Mpps , Backplane switching capacity: 320 Gbps
IP router interfaces: 128 , Static routes: 256 , Virtual interfaces (VLANs): 4000
MAC Address Table Size
32K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
RIP-1, RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, ECMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2, CLI
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, PIM-SM snooping, MSTP support, DHCP snooping, ACL support, QoS, Jumbo Frames support, DHCP server, LACP support, LLDP support, DHCP relay, LACP, GVRP, dual firmware images, NDP, 16MB packet buffer, PIM-DM snooping
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
Power Redundancy
44 cm x 33 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7, Windows 8
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS
Built-in Devices
Led panel
Status Indicators
Power, system, RPS (Redundant Power Supply), link/activity
24 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 1 x console RJ-45 management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Power Redundancy
4 rubber feet
Rack Mounting Kit
Included
FCC, RoHS
Software Included
Drivers & Utilities
44 cm
33 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
BLZ6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £13.84
