TP LINK JetStream 24-Port Gigabit L2+ Managed Switch with 4 10GE SFP
Quicklinx: G6WWWS00 Mfr#: TL-SG3428X
Type: Gigabit Ethernet
Ports: 28
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£208.74 ex VAT
£250.48 inc VAT
  • 10G Lightning-Fast Uplink: 4× 10 Gbps SFP+ slots enable high-bandwidth connectivity and non-blocking switching capacity.
  • Gigabit Speeds: 24× gigabit RJ45 ports offer high-speed and reliable connections to other switches and devices.
  • Integrated into Omada SDN: Zero-Touch Provisioning (ZTP), Centralised Cloud Management, and Intelligent Monitoring.
  • Centralised Management: Cloud access and Omada app for ultra convenience and easy management.
  • Static Routing: Helps route internal traffic for more efficient use of network resources.
  • Robust Security Strategies: IP-MAC-Port Binding, ACL, Port Security, DoS Defend, Storm control, DHCP Snooping, 802.1X, Radius Authentication, and more.
  • Optimize Voice and Video Applications: L2/L3/L4 QoS and IGMP snooping.
  • Standalone Management: Web, CLI (Console Port, Telnet, SSH), SNMP, RMON, and Dual Image bring powerful management capabilities
  • High switching capacity
    The TL-SG3428X provides a switching capacity of 128 Gbps, allowing for rapid data transmission across your network. This feature ensures that heavy traffic loads can be managed effectively without any interruptions.
  • Extensive port options
    Featuring 28 ports, including 24 for 10/100/1000 Mbps and 4 for 10 Gigabit SFP+, this switch supports a range of network configurations, accommodating various devices and network setups.
  • Packet forwarding performance
    With a packet forwarding rate of 95.23 Mpps, the TL-SG3428X manages high workloads efficiently, making it ideal for both small and large networks.
  • Advanced security measures
    This model incorporates multiple security features including DoS attack prevention, VLAN support, and Access Control List (ACL) capabilities, ensuring your network remains protected against various threats.
  • Robust management capabilities
    Offering a variety of remote management protocols like SNMP and Telnet, the TL-SG3428X allows for easy monitoring and configuration, streamlining the management of network resources.
TP-Link JetStream TL-SG3428X - V1 - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Packet forwarding rate: 95.23 Mpps
Priority queues: 8 , VLAN groups: 4000
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, ICMP, DHCP, RSTP
Flow control, VPN support, BOOTP support, ARP support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, DLDP support, fanless, LLDP support, DHCP relay, LACP, Port Security, MVR, NDP, port isolation, 12MB packet buffer, CoS, SP, GVRP, 802.1x authentication, cloud managed, DSCP support, IP source guard, ARP inspection, BPDU, dual image support, SDN, AAA, LLDP-MED, VLAN group, guest access, ZTP, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, Advanced QoS, MAB, security slot (Kensington security lock compatible)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL 3.0, TLS 1.2
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Status
24 x 1000Base-T RJ-45 , 4 x 10GBase-X SFP , 1 x console RJ-45 , 1 x micro-USB console
Internal power supply
23.6 Watt
Rubber feet
Rack Mounting Kit
Included
FCC, RoHS
44 cm
18 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
G6WW TP LINK 10GBase-SR SFP+ LC Transceiver In Stock £24.89
Ports: 28
Managed: Yes
POE: No
Brand: TP LINK
