TP LINK JetStream 24-Port 10/100Mbps + 4-Port Gigabit Smart Switch
Quicklinx: G6XBWS00 Mfr#: TL-SL2428P
Type: Fast Ethernet
Ports: 24
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE
More than 50 In Stock
£172.41 ex VAT
£206.89 inc VAT
The T1500-28PCT provides 24 10/100Mbps ports that supports 802.3at/af-compliant PoE, with a total PoE power supply up to 180W, powerful and flexible enough for users to deploy wireless access points or IP-based network surveillance cameras. The switch also comes equipped with 4 10/100/1000Mbps RJ45 ports and 2 combo SFP slots, expanding your network flexibly. In addition, it provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK Smart PoE Switch T1500-28PCT is a cost-effective product solution for the small and medium business. T1500-28PCT has useful security features. The Storm Control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch, TP-LINK smart PoE switch T1500-28PCT provides you the ideal access-edge solution.
  • Abundant Layer 2 features
    For more application of layer 2 switches, T1500-28PCT supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, Port Isolation, Port Mirroring, STP/RSTP/MSTP, Link Aggregation Group and 802.3x Flow Control function. Any more, the switches provide advanced features for network maintenance such as Loop Back Detection, Cable Diagnostics and IGMP Snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling & filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
  • Enterprise Level management features
    T1500-28PCT is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) or SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
  • Advanced QoS features
    To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including Port Priority, 802.1P Priority and DSCP Priority, to ensure that voice and video are always clear, smooth and jitter free. In conjunction with the Voice VLAN the switch supports, the voice applications will operate with much smoother performance.
TP-Link Smart PoE Switch T1500-28PCT - switch - 24 ports - rack-mountable
Switch - 24 ports
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE) + 2 x SFP + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
Performance
Bandwidth: 12.8 Gbps , Forwarding performance: 9.5 Mpps
Active VLANs: 512
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, manageable, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, VCT technology, MSTP support, QoS, SSH support, MIB, CoS, Loopback, DSCP support, 2 fans
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
44 cm x 22 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP, Microsoft Windows 7 / Windows 8
Switch - 24 ports
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
Active VLANs: 512
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Port transmission speed, power, link/activity
24 x 100Base-TX RJ-45 PoE , 4 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP
Internal power supply
Rubber feet
Rack Mounting Kit
Included
FCC, RoHS
44 cm
22 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 24
Managed: Yes
POE: PoE
Brand: TP LINK
