TP-LINK gigabit smart switch TL-SG2216 is equipped with 16 gigabit RJ45 ports and 2 combo SFP slots. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK gigabit smart switch TL-SG2216 is a cost-effÂective product solution for the small and medium business. TL-SG2216 has useful security features. The storm control feature protects against broadcast, multicast and unknown unicast storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with CLI, SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and gigabit capability, TP-LINK gigabit smart switch TL-SG2216 provides you the ideal access-edge solution.
                Advanced QoS featuresTo integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including port priority, 802.1p priority and DSCP priority, to ensure that voice and video are always clear, smooth and jitter free.
                Abundant layer 2 featuresFor more application of layer 2 switches, TL-SG2216 supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, port isolation, port mirroring, STP/RSTP/MSTP, link aggregation group and 802.3x flow control function. Any more, the switch provides advanced features for network maintenance such as loop back detection, cable diagnostics and IGMP snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
                Enterprise level management featuresTL-SG2216 is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) and industry-standard Command Line Interface (CLI). SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
- TP-Link JetStream TL-SG2216 - switch - 16 ports - Managed - rack-mountable
- Switch - 16 ports - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 + 2 x combo Gigabit SFP
- Performance
- Bandwidth: 32 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 10160 bytes
- Remote Management Protocol
- HTTP
- Auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, QoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 26 cm x 4.4 cm
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 8K entries
- 10160 bytes
- HTTP
- Status Indicators
- Power, system, 1000M device connected, link/activity
- 16 x 1000Base-T RJ-45 , 2 x Ethernet 1000 - SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- FCC
- 44 cm
- 26 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
