TP LINK JeStream 12-Port 10GBase-T Smart Switch
Quicklinx: CMCBWS00 Mfr#: T1700X-16TS
Type: Gigabit Ethernet
Ports: 12
Managed: Yes
£562.74 ex VAT
£675.28 inc VAT
In a world of expanding enterprises and growing virtualization, cloud-based services and applications, like VoIP, HD streaming video, and IP surveillance, SMB networks need to evolve beyond simple reliability to provide increased scalability, higher bandwidth, and enhanced performance. TP-LINK’s T1700 Series 10G Smart Switches represent an ideal solution that meets these requirements. The switches provide high levels of performance, scalability, and cost-effectiveness that SMBs require from their 10G networking solutions.
  • 10GBase-T technology
    Until recently, 10-Gigabit connectivity was available only in the expensive fiber based technology that supports high-speed access to the network backbone or data center environment. Today, 10GBase-T Technology is becoming more common and affordable. Low-Latency, Line-Rate 10G Copper Base-T is backward compatible with Fast Ethernet and Gigabit Ethernet and can automatically negotiate between higher and lower speed connections. Most importantly, 10GBase-T provides a cost-effective method for migrating from your current network to 10G Ethernet by utilizing your existing CAT5e/CAT6 RJ-45 short connections (up to 55m) and CAT6A/CAT7 connections (up to 100m). This reduces cabling complexity and ultimately results in significant savings for customers.
  • 320Gbps switching capacity
    The T1700X-16TS features 12 10GBase-T RJ45 ports and four dedicated SFP+ fiber slots, which can support up to 320Gbps of combined switching bandwidth. This provides great resiliency, relieves congestion associated with bandwidth-intensive applications, and guarantees smooth data transmission.
TP-Link JetStream T1700X-16TS - switch - 12 ports - smart - rack-mountable
Switch - 12 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10GBase-T + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 320 Gbps , Forwarding performance: 238.1 Mpps
IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP groups: 1000 , VLAN groups: 4000 , Priority queues per port: 8 , ACL entries: 300
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, static IP routing, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DAI, Cable Diagnostics Function, bandwidth control, LLDP support, DHCP relay, LACP, Port Security, IP-MAC binding, SNMP trap, MIB, NDP, 2MB packet buffer, port isolation, static routing, CoS, Loopback, DSCP support, 2 fans, system log, BPDU, ICMP, dual image support
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3an
44 cm x 22 cm x 4.4 cm
4 kg
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Port transmission speed, power, system, link/activity, fan
12 x 10GBase-T RJ-45 , 4 x 10Gbit LAN SFP+
Internal power supply
76.58 watt
Rubber feet
Rack Mounting Kit
Included
FCC, RoHS
Software Included
Drivers & Utilities
44 cm
22 cm
4.4 cm
4 kg
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 12
Managed: Yes
Brand: TP LINK
Price Range Ex VAT: £500 - £750
