TP LINK HS100 Kit Kasa Smart Wifi Plug 2-Pack
Quicklinx: F0W6WS00 Mfr#: HS100 KIT V2.1
Smart Control for A Smart Home
Manage Your Home Electronics and Appliances Anytime, Anywhere
The smart plug is easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Add an extra layer of security with Away Mode. Connected devices will randomly turn on and off throughout the day to make it look like you’re home.
Modern, Elegant, Simple
Inspired by a modern sensibility, the smart plug's design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The smart plug gives you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
  • Remote access
    Control devices connected to the smart plug wherever you have Internet using your smartphone.
  • Scheduling
    Schedule the smart plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
  • Energy monitoring
    Analyze a device's real-time and historical power consumption.
  • Away mode
    Turns your devices on and off at different times to give the appearance that someone is home.
TP-Link HS100 - smart plug
Smart plug
Packaged Quantity
2 (specifications are for single item)
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android
United Kingdom
10.03 cm x 6.63 cm x 4.68 cm
Warranty
2 year warranty
Packaged Quantity
Smart plug
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Android 4.1 (Jelly Bean) or later, iOS 9 or later
Power scheduling
Internet of Things (IoT)
United Kingdom
Power Provided
3.12 kW
RoHS
10.03 cm
6.63 cm
4.68 cm
290 g
Shipping Width
18.6 cm
Shipping Depth
14 cm
Shipping Height
8.8 cm
Shipping Weight
460 g
10 - 90% (non-condensing)
