TP LINK Easy Smart TL-SG105PE Switch - Managed - 5x 10/100/1000 (4 PoE+) PoE+ (65 W)
Quicklinx: FZ6MWS00 Mfr#: TL-SG105PE
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
32 In Stock
£51.79 ex VAT
£62.14 inc VAT
Standard delivery Delivered within 3-5 working days
  • Five 10/100/1000Mbps RJ45 ports
  • Equipped with four 802.3af/at PoE+ ports with up to 30W for each port, data and power can be transferred on one single cable
  • Supports PoE power up to 65 W for all PoE ports
  • Provides network monitoring, traffic prioritization, VLAN features, and PoE Auto Recovery
  • Simple network set-up on top of plug-and-play connectivity
  • Web-based user interface and Easy Smart Configuration Utility simplify configuration
TP-Link TL-SG105PE - switch - 5 ports - Managed
Switch - 5 ports - Managed
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 (4 PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
65 W
Performance
Switching capacity: 10 Gbps , Packet forwarding rate: 7.44 Mpps
Packet buffer size: 1.5 MB , Priority queues: 4 , Virtual interfaces (VLANs): 32
MAC Address Table Size
2K entries
Jumbo Frame Support
16KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward, Cable Diagnostics Function, fanless, loop prevention, tagged VLAN, DSCP support, Storm Control, rate limit, Static Link Aggregation, extend mode
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
65 W
Performance
2K entries
Jumbo Frame Support
16KB
Routing Protocol
Status Indicators
Status
5 x 1000Base-T RJ-45 4 ports (PoE+) - 30 W
External power adapter
Power Provided
DC 53.5 V - 1.31 A
75.16 Watt
Rubber feet
FCC, RoHS
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Ports: 5
Managed: Yes
POE: PoE+
Brand: TP LINK
