- Five 10/100/1000Mbps RJ45 ports
- Equipped with four 802.3af/at PoE+ ports with up to 30W for each port, data and power can be transferred on one single cable
- Supports PoE power up to 65 W for all PoE ports
- Provides network monitoring, traffic prioritization, VLAN features, and PoE Auto Recovery
- Simple network set-up on top of plug-and-play connectivity
- Web-based user interface and Easy Smart Configuration Utility simplify configuration
- TP-Link TL-SG105PE - switch - 5 ports - Managed
- Switch - 5 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000 (4 PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 65 W
- Performance
- Switching capacity: 10 Gbps , Packet forwarding rate: 7.44 Mpps
- Capacity
- Packet buffer size: 1.5 MB , Priority queues: 4 , Virtual interfaces (VLANs): 32
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 16KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward, Cable Diagnostics Function, fanless, loop prevention, tagged VLAN, DSCP support, Storm Control, rate limit, Static Link Aggregation, extend mode
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 65 W
- Performance
- Capacity
- 2K entries
- 16KB
- Routing Protocol
- Status Indicators
- Status
- 5 x 1000Base-T RJ-45 4 ports (PoE+) - 30 W
- Power Device
- External power adapter
- Power Provided
- DC 53.5 V - 1.31 A
- 75.16 watt
- Included Accessories
- Rubber feet
- FCC, RoHS
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
